Old 11-30-2014, 06:26 PM   #526
oldman3
oldman3's Avatar
Re: Project "Popeye"
Can't wait to see the parts and assembly begin...Jim
oldman3 is offline   Reply With Quote
Old 11-30-2014, 09:12 PM   #527
99 to Life
99 to Life's Avatar
congrats can't wait to see the end result
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-02-2014, 01:14 AM   #528
Marty68
just read the whole thread took nearly 2 days. very nice!! i am envious of your ability to maintain a clean work area. my place is not so tidy. i would love to find one of these to do would even give my 68 for one as nice as you started with.
Marty68 is offline   Reply With Quote
Old 12-03-2014, 08:40 PM   #529
LEEVON
Moderator
LEEVON's Avatar
Haha thanks! But I only take pictures when the space is clean...believe me I can make a royal mess
So I took care of a little project in preparation for the fuel system/tank installation. I wanted to sound deaden and insulate the back of the cab so I took care of that and insulated the roof. Peel and Seal and foil-faced bubble wrap type insulation from Lowe's were used. I heated the Peel and Seal after applying it with a heat gun then rolled it with a seam roller to make sure it's stuck on for good. The insulation was adhered using 3M Super 77 spray adhesive.
All in all a quick, cheap and easy project that should yield a good return. I will probably do more of the floor and some or all of the firewall at a later time.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-03-2014, 09:53 PM   #530
reaper71
reaper71's Avatar
does the peel and seal have strong odor? Like tar...
Also where did you find at Lowes
Looks great Btw...
Mark
reaper71 is offline   Reply With Quote
Old 12-03-2014, 10:29 PM   #531
LEEVON
Moderator
LEEVON's Avatar
No odor, that's more likely with products having a higher asphaltic contect. It's found in the roofing section.
Old 12-03-2014, 10:39 PM   #532
99 to Life
99 to Life's Avatar
looks good, I'v heard of guys going that route with the deadners. I've searched for a quite a bit on the subject. I've even got the weights from fatmat on the different ones they use for ex. The odor ones come from what most companies use which is the mastic compound, some are just gonna be worse than others.
The one I'm leaning toward and is more money though is the butyl-rubber. Its said to be the best dampening material, some guys sell 50 and 70mil thick.
I'v found 50sq ft of the butyl for $75 50mil thick, not made in china
do you know how many sq ft you got and how much its was?
Old 12-03-2014, 10:57 PM   #533
LEEVON
Moderator
LEEVON's Avatar
Agree on the butyl rubber materials...definitely better options out there than peel and seal. I bought two rolls 25'x6" for about $16/each and the insulation for about $24, plus some foil tape for a couple bucks.
Old 12-03-2014, 11:30 PM   #534
vht
The Peal and seal is where the flashing is at Lowe's. I like to never found it.
vht is offline   Reply With Quote
Old 12-04-2014, 11:00 AM   #535
reaper71
reaper71's Avatar
Thank's guys for the info..
Mark...
Old 12-04-2014, 06:45 PM   #536
Henney
99 where did you find that deal?
Henney is offline   Reply With Quote
Old 02-16-2015, 10:25 PM   #537
iowaboynca
iowaboynca's Avatar
Any updates Leevon? You're so close....and like you said we're like fat kids and cake...
Can't speak for everyone but i'd take a solid bet there's a few of us that want to see Popeye on the road!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 09-07-2015, 12:05 PM   #538
51Chevy3100
Just went thru your build because I plan to accomplish a very similar setup and you were doing great! What's the story on popeye these days?
1951 3100 Patina "Under Construction"
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=636116
87 V30 1 ton Mud Truck
51Chevy3100 is offline   Reply With Quote
Old 10-09-2015, 11:00 AM   #539
LEEVON
Moderator
LEEVON's Avatar
Sadly I am still dragging this build out and Popeye is not running yet, however he is not far from being done. What you can see in the pictures are a shortened and completely rebuilt '69-71 non-tilt steering column, brand new glass and rubber, new headlight buckets and guts, and new pin striping. The "Jessica Marie" lettering with angel's wings on the tailgate is a tribute to my sister who passed away in 2010 after I started this build.
Old 10-09-2015, 11:17 AM   #540
05snopro440
05snopro440's Avatar
Popeye is looking good! Not that far to go, get that sucker done!
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
05snopro440 is offline   Reply With Quote
Old 10-09-2015, 11:18 AM   #541
99 to Life
99 to Life's Avatar
awesome, luv this truck, nice tribute. I remember when you posted that years ago. Very sad.
Old 10-09-2015, 11:28 AM   #542
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks great!
Keith
Convert to disc brakes.
Old 10-09-2015, 12:13 PM   #543
Coach529
Coach529's Avatar
Thanks for the update!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 10-09-2015, 02:47 PM   #544
sam86
That tribute looks great!
sam86 is offline   Reply With Quote
Old 10-09-2015, 03:53 PM   #545
58-GMC
58-GMC's Avatar
Love the pin striping!
Build Thread: 1958 GMC Memorial Build
58-GMC is offline   Reply With Quote
Old 10-09-2015, 04:03 PM   #546
05snopro440
I think I need a steering column similar to that for my new project, thanks for the idea. Love the tribute!
Old 10-09-2015, 05:38 PM   #547
LEEVON
Moderator
LEEVON's Avatar
It worked out well. I did move the hole in the floor down about 4" and to the driver's side about 3". I thought the column would be fine as-is but once I dis-assembled it for shortening I realized it needed upper and lower bearings and the cancelling cam/harness connection. The shaft, inner and outer tube were all cut and shortened 2". I also had to create my own bearing retainer on the end of the lower bearing. But it all worked out well, shifts and turns very nice.
Old 10-09-2015, 08:36 PM   #548
oldman3
oldman3's Avatar
Glad to see the update, truck looks great...Jim
Old 10-09-2015, 08:47 PM   #549
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks good bud
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-09-2015, 10:56 PM   #550
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Looking good. Keep at it.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
