5.3 swap
I Have A 65 Trying To Do A LS Swap But I Need More Info. Can somebody
Guide me to the right direction. Can I use the original mounts Headers Etc.. thanks guys. |
Re: 5.3 swap
I'm in the process of doing one myself in my 64 c10. I bought a kit that comes with motor mounts headers and trans crossmember..
Re: 5.3 swap
Where did u get it? Who makes it
Thanks in advance |
Re: 5.3 swap
I got mine from Classic performance products it was $869.
http://www.classicperform.com/Store/...e_Upgrades.htm |
Re: 5.3 swap
In the engines section of this site is a lsx swap section. This might help a little.
http://67-72chevytrucks.com/vboard/f...play.php?f=206 |
Re: 5.3 swap
Thanks. That's a little over my budget. I'm trying to find
I'm going to check out the lsx swap section. Thanks. |
![]() Join Date: Aug 2004
Re: 5.3 swap
Look at the FAQ in that section, several ways to skin that cat.
If inexpensive is what you want. You "can" use the stock perches, however it is tough to get the bolts in the mounts!!! I suggest some 73 up perches ( Called Clam Shell) and some dirty dingo slider mount plates, SBC motor mounts, then a CPP tubular trans mount ( unless your going with a different trans that the 4l60e) Im up the road, just north of Burleson if you need more info.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
