Old 12-03-2014, 02:17 AM   #1
gt40racing
gt40racing's Avatar
Tire Size Lowering 69 C20
I will be running 16 x 6.5 wheels and I was wondering what size tires your guys are running... going to run the 2/4 drop kit...Thanks
gt40racing is offline   Reply With Quote
Old 12-03-2014, 01:17 PM   #2
Mike C
Mike C's Avatar
Re: Tire Size Lowering 69 C20
What size tires are on it now? Do you plan on using it like a truck? IE: do you need load capacity or are you considering passenger car tires? What gears are in the truck and do you need tire height to knock the RPM down?
On my 70 C2500 GMC I left it stock in front and did 1 1/2" lowering shackles in the rear. (Leaf spring truck) With 265 75 16 on 16x8 inch Alcoa rims. I had 3.54 gears in the Dana 60. My truck was a 7500 GVWR truck (maximum for the platform) with a big block and air so it had the heaviest rated springs for a 2500.
Keeping in mind it's a 3/4 ton truck, I'd go with 215 75 16 or 225 75 16 tires with at least a D rating in your case. 215's gives you about a 28 1/2" tire height compared to the 31 1/2" height on my 265's.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-03-2014, 02:49 PM   #3
seth7843
seth7843's Avatar
67 C20 stock height with 245 75 16.
seth7843 is offline   Reply With Quote
Old 12-03-2014, 03:04 PM   #4
benner
benner's Avatar
I ran into very few choices for wheels and tires with stock 16.5's so went to a 17' wheel...lots more choices now. Still a hauler but I can put larger tires on rear. Good luck with your choices.
benner
Blacked out 1970 CST, C 20. Hardcore Work Truck with 350, Edelbrock 750, RPM High Rise, Flow-Masters, Black wheels and a Log Wood Rack. One Hot Worktruck.
benner is offline   Reply With Quote
Old 12-03-2014, 07:57 PM   #5
Stranny64
Stranny64's Avatar
My info is in my signature if your interested. Good Luck!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!)
Stranny64 is offline   Reply With Quote
Old 12-03-2014, 11:35 PM   #6
JustinGJ
225-75R16, load range E, got the tires for free and like the size on the truck. One coil cut from the front big block springs that are now supporting a 350, about a 2.25" shackle drop in the rear. Might pull a leaf out of the rear to level it a bit more. The first pic is right after chopping the springs.
71 C-20 Custom Deluxe
350-TH400
Blue/white standard two-tone
92 K1500
350-4L60
Blue/white two-tone
JustinGJ is offline   Reply With Quote
Old 12-06-2014, 04:33 PM   #7
gt40racing
gt40racing's Avatar
Truck has an incomplete body lift that I am removing and returning to stock.
Old 12-06-2014, 05:28 PM   #8
1969Chev
1969Chev's Avatar
Im running 235/65/16 in front and 275/60/16 in the rear. 5/7 drop.
1969 CST/20 396/TH400 Tach Posi
1969Chev is offline   Reply With Quote
Old 12-06-2014, 07:19 PM   #9
gt40racing
gt40racing's Avatar
Nice looking truck...
Old 12-06-2014, 08:13 PM   #10
Mike C
Mike C's Avatar
Decide if you want to keep truck tires on it or passenger tires is the first step. I don't think a tire shorter than 28" looks right on these trucks keeping this in mind.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-06-2014, 10:37 PM   #11
gt40racing
gt40racing's Avatar
I like this stance.....
Old 12-07-2014, 12:06 AM   #12
1969Chev
1969Chev's Avatar
Thanks gt40!
I used to have those wheels too
Old 12-07-2014, 10:07 AM   #13
Stranny64
Stranny64's Avatar
1969chev, how did you get it that low? What is your rear end gears? I'm kind of limited with 4:10 gears so I need a taller tire.
Old 12-07-2014, 10:44 AM   #14
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
67 GMC bone stock height, "Kirkland Signature" 235/75R15 M+S. All the way around. I bit bouncey
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 12-07-2014, 02:15 PM   #15
1969Chev
1969Chev's Avatar
Well my truck has factory 4.10s, I'm the 2nd owner but i think the 1st owner swapped the 4.10s with 3.73s. And i have 3 inch lowering springs with a full coil cut in the front, and 5 inch lowering springs out back with 2 inch blocks. I dont have a c-notch, but i sometimes hit my axle on my frame.
