Old 01-25-2004, 12:19 AM   #1
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
Rear Rollpan Install Questions
I purchased a rear Rollpan for my 72' with the Fleetside box from Wes. When mocking up the pan before I weld it in I've noticed a few things. One, I need to trim about 3/16" off of each end for it to fit so I can weld it in. What's the best way to do this? Also, how am I supposed to access the lower bolt on the Tailgate hinges? It seems like I won't be able to get a wrench back behind there to tighten them down once its installed. Any help here would be great.
Thanks,
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 01-25-2004, 01:43 AM   #2
Sweet72
Sweet72's Avatar
A cutoff wheel on a die grinder works great for trimming sheet metal. You'll have to cut access holes in your roll pan (large enough to work a wrench) to get to the tailgate trunion bolts. Cut them where they won't be seen (just below the ends of the tailgate) with the tailgate closed. Good luck!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-25-2004, 01:45 AM   #3
71swb4x4
71swb4x4's Avatar
I have a roll pan and I can get the tailgate on and off just fine. Yours must be built a little differently. I can take pics tomorrow if you want.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-25-2004, 04:40 AM   #4
PrimeredThunder
Back from the Dead
Pic PLEASE! I would like to see the clearance!
Also, are you talking about notching the pan on the top or bottom for wrench clearance?
Salem, Oregon
Old 01-25-2004, 04:43 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What manufactureer was the pan made by???? I have been looking at getting a SIR MICHAEL'S but just have not ordered it yet..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-25-2004, 04:52 AM   #6
PrimeredThunder
Back from the Dead
I believe it is a mark-k pan. There is nothing wrong with the pan itself. I think that the manufacturer made it 67" long that way it can fit a variety of trucks, since I'm sure throughout the years most beds have been dis/reassembled. My gap is 66 5/8". I asked Wes about this and he measured the fleetside boxes on teh trucks he had and came up witha few different measurements. Like he said, its a lot easier to remove metal than have to fil it in.
Salem, Oregon
Old 01-25-2004, 01:47 PM   #7
71swb4x4
71swb4x4's Avatar
I went out to take a pic and I really don't have the clearance that I thought I did. It is a tight fit. Not sure I could get the tailgate off very easily at all.
Shawn
Old 01-25-2004, 03:37 PM   #8
bigjimzlll
bigjimzlll's Avatar
I know this isn't the correct way...but I left off the bottom bolts on the hinge..the roll pan I got from wes need only trimming for the licence plate reccess
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-25-2004, 04:34 PM   #9
PrimeredThunder
Back from the Dead
Yeah I might end up leaving them off like bigjimzlll did. Like I said, the company makes the rollpans as a universal fit application; some will and some wont need trimming.
Salem, Oregon
