Old 12-09-2014, 12:46 PM   #1
WEBBY1
WEBBY1's Avatar
trailing arm help
I swapped to 5 lug axles and had my rear narrowed.. I put 4" blocks on the trailing arms..I'm running 28" tall wheel. I'm having an issue with the rear end moving forward out of notch even I drop my suspension. Here's a pic.. what can I do to correct this problem. I see that pb makes a trailing arm kit... Will this take care of my problem? Thanks in advance.
WEBBY1 is offline   Reply With Quote
Old 12-09-2014, 01:36 PM   #2
PGSigns
PGSigns's Avatar
Re: trailing arm help
Tell us more about your problem. When you say "I'm having an issue with the rear end moving forward out of notch even I drop my suspension." Are you talking about the well is no longer centered in the wheel well?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-09-2014, 01:36 PM   #3
LVPhotos
LVPhotos's Avatar
Porterbuilt arms. If you have stock arms it pushes up and forward. Porterbuilt arms come with 1 or 3" drop built in. Some where here is a thread on this issue of pushing tire into bed. I do have pic on my build thread as well.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-09-2014, 01:45 PM   #4
WEBBY1
WEBBY1's Avatar
If you notice the axle is at the front of the notch and not centered. Theres still about 8 inches before the body lays on the ground jimmy... LV im gonna get a hold of pb and see what they recommend
Old 12-09-2014, 04:21 PM   #5
luvbowties
luvbowties's Avatar
Smile Re: trailing arm help
I'm talking out of my league here, as I've never been involved in your project. But, could you put extension blocks onto the front of your tr-arms to move your differential back into perspective?...kinda like relocating front support backwards?
Remember, I'M learning as YOU go!
Sam
luvbowties is offline   Reply With Quote
Old 12-10-2014, 11:23 AM   #6
PGSigns
PGSigns's Avatar
I'm not a fan of the blocks being more than about an inch. When you get that much block on it it will move the rear end forward. It also leaves the truck arm hanging below the rim and close to the ground with most wheels 20" and smaller. If you have a flat the ubolts can dig into the pavement causing control issues. If you flip your front brackets and raise the front of the truck arms up the 3 1/2" or so it gives you you can get rid of most the block and also keep the drop you have. This will move the wheel back to about where it started.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
