Old 12-09-2014, 04:53 PM   #26
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Idea for spotting fake shortbeds
Originally Posted by cleanfreak View Post
Has it been posted here that some frames do not have the vin stamped in them?
My brother's 70 GMC shortbed Sierra Grande frame does not have any numbers stamped into it. Not on the front driver's frame rail or under the cab. Looks to be all original, just never stamped.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 12-09-2014, 05:24 PM   #27
no1udknow
no1udknow's Avatar
Originally Posted by Livrat View Post
I mostly agree with you, except for one item that I did not notice for many years, not all longbeds have the curve you mention, 1967 "only" longbeds are not curved in the lower front wheel well.
I guess I should take a look at that since the drivers bed side is a 67, and the passenger bedside is a "who knows?" .... so the wheel well corners likely dont match
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 12-09-2014, 05:49 PM   #28
DarkFlounder
My first thought was "Jeez, these aren't Shelby Cobras or GT500 Mustangs. Is there really a market for faked shortbeds?"
My next thought was "Great, those of that that prefer longbeds won't have to worry about getting our desired trucks bought up."
Final thought was "But if all the longbeds are being cut up into shortbeds, then we're going to run out of longbeds!"
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline   Reply With Quote
Old 12-09-2014, 06:18 PM   #29
CG
BlahBlahBlah
All of a sudden that 67 long box I have filled full of scraps and junk becomes worth more than just a storage container lol.
And Im pretty sure the GMC's didn't have the frame stamped. Never owned a GMC, but I think Ive read it here on the board a time or two.
Old 12-10-2014, 12:04 PM   #30
pat english
pat english's Avatar
Another good tip woulkd be to look for the rear cab mounts to be bolted on.most poeple use nuts and bolts when relocating the rear cab mounts.
(I have a chopped frame.I love it like its a real shortbed though...)
pat english is offline   Reply With Quote
Old 12-10-2014, 12:45 PM   #31
Primered_69
Primered_69's Avatar
and mine our bolted in as well...good catch
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 12-10-2014, 08:33 PM   #32
R.L.
R.L.'s Avatar
Well mine's cut down and I'm just as proud of it as if it were factory but if you want to know if it's been modified look at the frame, you'll see if it's been cut and wielded. You know you need to look under it before you buy it anyway. If it matters to you then you'll know.
R.L. is offline   Reply With Quote
Old 12-10-2014, 08:58 PM   #33
Gene
Gene's Avatar
Originally Posted by RManson View Post
What about the longbed truck that's been swapped with an aftermarket short wheelbase chassis and shortbed? Worth more? Worth less? Worth inbetween? lol
Personally I couldn't care less as long as the work was done right. Then again, I'm not the type of person who loses sleep over "non-original" appointments.
I would be more concerned about botched body and sheetmetal repairs as those can get expensive. Swapping a frame is kinda easy.
I can tell you first hand that there are some that don't care. I took a 71 LWB, put the cab and front end and a factory short bed on an original 4x4 SWB frame and converted the truck to a 4wd. After an extensive restoration I sold the truck and fully disclosed all the modifications to the buyer. I'm not going to say how much I sold the truck for but I got all my money back that I invested. He was thrilled, I was thrilled.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 12-10-2014, 10:13 PM   #34
yellow&white72
I think as long as the work is done right and the truck is safe there is nothing wrong with a cut down truck. I cut my truck down about 5 years ago and put a real swb on it and have never had a problem.
yellow&white72 is offline   Reply With Quote
Old 12-10-2014, 11:48 PM   #35
LEEVON
Moderator
LEEVON's Avatar
So this all begs the question...if it is done well enough that you couldn't possibly figure it out...does it really matter? ; )
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-11-2014, 12:08 AM   #36
Chuck Burg
Chuck Burg's Avatar
If Its done right, it will have fish plates welded over the cuts on the frame. It's not if you can't tell, its was it done right.
This is how its done.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Chuck Burg is offline   Reply With Quote
Old 12-11-2014, 12:20 AM   #37
HemiChallenger71
HemiChallenger71's Avatar
I have nothing to add other than I could never understand the fascination of a short bed over a long bed.
HemiChallenger71 is offline   Reply With Quote
Old 12-11-2014, 12:37 AM   #38
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
Ya know, I was wondering the same thing myself. My '75 F100 is a short box but my old GMC was a long bed, sometimes it's nice to have a short bed, sometimes its nice to have a long bed. I would of bought either truck no matter the length of the box!! Just my opinion!!!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 12-11-2014, 08:01 AM   #39
hamjet
hamjet's Avatar
I like the LBs and SBs from that era, but to see the trucks today with exdended cabs and a 4 foot box look hidious to me...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 12-11-2014, 10:55 AM   #40
68shortwide
68shortwide's Avatar
Depends on how you wanna use the truck, lwb for a hauler or lifted, or even low slung look. shorty if you want it to handle and be fast look nice as hell (me )
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 12-11-2014, 02:37 PM   #41
Lees68GMC
Lees68GMC's Avatar
QUIZ Quaestions, Is this 68 Chevy a Real or FAKE Shortbed? Which is the REAL Shortbed?, the 68 C10 or the 68 GMC? Doesn't really matter to me when the quality of the work is Great.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 12-11-2014, 04:28 PM   #42
73737373
I am not an advocate of doing anything to a truck that it didn't come from the factory with. I realize that's kind of a reactionary point of view, but understand those that do modify for whatever reason and whatever those modifications happen to be. I am in awe of the many many talented individuals on this forum that have the skills and discipline to make their trucks look terrific; short bed or long bed. Value is in the eye of the beholder and that's the key, but one thing will always remain constant; well done work will always be worth more than shoddy work.
Personally, I wouldn't walk across the street and pee on short bed truck if I saw it burning, and the only reason I keep my 68 shorty is because I've had it 31 years, but I think a well done long bed truck will be worth more than a PoS shortbed.
Again, I applaud all of you have done things "right" w/your trucks. It upsets me to see the hacker work and the landscape (and Craig's List) littered with what were once perfectly good trucks that are now nothing more than piles of parts because soemone didn't know what they were doing.
73737373 is offline   Reply With Quote
Old 12-12-2014, 08:41 AM   #43
Keith Seymore
Keith Seymore's Avatar
Wow. I hope your truck never catches on fire.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-12-2014, 08:56 AM   #44
73737373
Yeah, that was probably pretty strong, wasn't it? Hope no one was too offended....not my intent.
Old 12-12-2014, 09:08 AM   #45
Kennuck
Kennuck's Avatar
What about real swb converted from Stepper to Fleet? Thoughts?
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 12-12-2014, 10:29 AM   #46
aventur1
aventur1's Avatar
Kennuck
I've been asked that several times with comments of it would look better although I like the stepper. Since mine is lifted I use the step a lot to get into the bed.
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline   Reply With Quote
Old 12-12-2014, 12:50 PM   #47
leddzepp
Moderator
leddzepp's Avatar
I'm going to cut up my SWB and make it a LWB as Cdowns usually suggests
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-12-2014, 01:08 PM   #48
no1udknow
no1udknow's Avatar
Reminds me of a question I've heard before...
"if you didn't know she used to be a dude would it matter?"
Built not bought!
Old 12-12-2014, 02:31 PM   #49
zamboni2354
LB vs SB for me is just personal preference...and my personal preference may sound weird but for a lowered 2wd truck I like the short bed and for a taller 2wd or 4wd truck I like the long bed. The proportions just seems more balanced....
Regarding whether a shortened long bed has the same value of an original sb truck, For me personally it would lesson the value to an extent. I think of it this way, if I saw two identical looking trucks and one was a chopped LB and the other an original SB and the price was the same I'd buy the original SB every time.
jeff in long beach.
zamboni2354 is offline   Reply With Quote
Old 12-12-2014, 02:35 PM   #50
CUSTOM/10
CUSTOM/10's Avatar
X2..... Well said !
jeff in long beach.
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
