Old 12-09-2014, 10:30 PM   #1
slotard
Better round lights
I'm looking for a headlight upgrade on my '73 C20. I've gotten spoiled by more modern headlights in more modern cars, and was hoping to find a new setup that'll work better without changing the appearance too much.
I've swapped from refractor type housings (where the lens plays a major role) to reflector type housings (where the lens is clear) on motorcycles and it seems to help. Are there any swaps like that for square bodies? I'd be happy with a different grill, but want to stick to the round headlights and would rather not go with HIDs unless I can find a housing designed for them.
slotard is offline   Reply With Quote
Old 12-09-2014, 10:48 PM   #2
dfrank
dfrank's Avatar
Re: Better round lights
Lmc truck sells what they call euro style headlights that look like the factory originals but use a modern style replacement bulb. They are very bright. I had them on my 86 for a while but took them off. The headlitht wiring harness is f'd up so when the high beam light is on the low beams are on and with the two stage bulb and 4 headlights it just pissed me off as the low beams where brighter than the high beams.
dfrank is offline   Reply With Quote
Old 12-09-2014, 10:53 PM   #3
MalibuSSwagon
I'm sure the LMC ones are the same types you can buy on ebay, Amazon, etc. It's a conversion housing that allows you to use H4 bulbs.
MalibuSSwagon is offline   Reply With Quote
Old 12-09-2014, 11:02 PM   #4
GMC Guy
GMC Guy's Avatar
I was thinking about buying a pair of these..
http://www.ddmtuning.com/Products/60...ogen-Lamp-pair
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 12-09-2014, 11:32 PM   #5
JonnyC10
I upgraded using the Hella Vision Plus ECE headlights that come with the Hella H4 bulbs and an upgraded headlight relay harness. I tell what, probably one one of the best mods I have done to the truck to date.
JonnyC10 is offline   Reply With Quote
Old 12-10-2014, 12:09 AM   #6
slotard
GMC Guy, the problem with buying drop in HIDs is that the pattern they throw is poor in a housing designed for halogens. This can blind oncoming traffic as well as making "hot spots" that decrease your night vision.
http://www.ebay.com/itm/130951094047 is about what I have on the motorcycle. I'm not sure if it would drop in without changes. It should provide better lighting, but isn't right for HIDs.
I might go with HIDs, but I'd need to do a proper retrofit rather than just drop bulbs in. I'm not sure if there are any high quality projectors mounted in 7" round housings.
Old 12-10-2014, 12:16 AM   #7
GMC Guy
GMC Guy's Avatar
or you could throw these in there
Amazon.com: Sylvania 9003 SU SilverStar Ultra... Amazon.com: Sylvania 9003 SU SilverStar Ultra...
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 12-10-2014, 12:46 AM   #8
Ziegelsteinfaust
Some jeep model with mods fit the housing and I am thinking of those.
Ziegelsteinfaust is offline   Reply With Quote
Old 12-10-2014, 12:55 AM   #9
67swb72klb
67swb72klb's Avatar
just Google 7" headlight you will find a lot of options
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-10-2014, 12:56 AM   #10
slotard
The LED Truck Lites: http://www.ebay.com/itm/281437873317 look nice, but are a little more money than I'd like to spend.
There are some Jeep-ish headlights that come with HIDs http://www.ebay.com/370871749214 but I'm still concerned they may not have a good pattern. The price is reasonable though, and I could also try running typical H4s in them.
Old 12-10-2014, 03:23 AM   #11
andrewmp6
There are some Jeep-ish headlights that come with HIDs http://www.ebay.com/370871749214 but I'm still concerned they may not have a good pattern. The price is reasonable though, and I could also try running typical H4s in them.[/QUOTE]
That ebay kit is total junk don't use any of it.The housings are the diamond cut/euro cut which won't focus the light.The hid part is cheap and using a hid in a none projector housing will blind people.For a good h4 housing hella brand or the stand autopal brand not the diamond cut ones.Get a h4 wiring harness with the relays that will help you get more power to the lights.The next step up is leds truck lite or jw speaker brand are nice but pricey.
Old 12-10-2014, 04:46 AM   #12
jjzepplin
jjzepplin's Avatar
Subbed
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-10-2014, 08:19 AM   #13
gmachinz
Do a HD relay upgrade first-you'll notice a huge difference in light output.
gmachinz is offline   Reply With Quote
Old 12-10-2014, 09:58 AM   #14
hatzie
Moderator
hatzie's Avatar
2008 Jeep Wrangler H13 Headlight assemblies are an improvement in reflector design. The convex Jeep lens looks like it belongs unlike the flat Hella E-Code assemblies that also have very good light output with Halogen bulbs. http://67-72chevytrucks.com/vboard/s...d.php?t=318973
You'll need a conversion harness. A good H4 to H13 relay harness will get more electrons to the lights than the 40 year old 18ga wiring... Without chopping up the original harness.
Like this --->http://puredieselpower.com/products/...onversion.html
As far as HID conversions go I'll just quote another member that has the same opinion as me. "I'm by no means an expert on this, but every car or truck that the owner slapped some cheap-o HID replacement bulb into didn't work worth $h!t. The factory or aftermarket manufacturer sells their headlights with H4, H1, H7, etc....bulbs because the reflector and lens were [hopefully] designed to work with the light output of those particular lamps. Putting in an HID H4 replacement bulb will do nothing but make your lights look blue and annoy oncoming traffic with their horrible glare. If you want true HID performance lighting you need to look for a unit that is designed from the get-go for HID lamps. IMHO- projector (aka- ellipsoidial) headlights are precisely designed for this application. Below is an example of what I'm talking about. Can you pick up a set for $80? No way, more like $500-$600! So if you are serious about performance lighting you'll need to shell out some cash. If that's out of the budget- go get some nice Hella E-Code Halogen units and put them in with some Silverstar bulbs and the ever-necessary relay upgrade and you will have very good light output!"
--http://67-72chevytrucks.com/vboard/s...8&postcount=11
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-10-2014, 11:43 AM   #15
slotard
I'll keep my eyes open fora set of Wrangler headlights, that's about what I was thinking of. Nice to know there's a good OEM one rather than ebay crap.
Old 12-10-2014, 12:21 PM   #16
cadillac_al
FWIW my 76 GMC with plain old halogens is brighter than my newer Buick or Caddy so I have no idea what you guys are talking about. I'm sure I could probably get some blinding lights for my '03 Caddy that would make the truck lights look dim, but I'm happy enough with stock. You can't beat those big round spotlights imo.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-10-2014, 01:39 PM   #17
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I added SilverStars to my truck and I am SUPER happy with them, they were about $24 a lamp, but they have been in the truck now for about 10 years with not one fail.
https://www.sylvania.com/en-us/produ...aled-beam.aspx
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 12-10-2014, 01:51 PM   #18
gmachinz
Here's a generality about relay harness kits for headlights....nobody ever seems to produce numbers to put things into perspective so, as far as the relay headlight kits I build, I observe on average a 1.5V gain in voltage to the headlights which represents roughly a 25% increase in brightness-that is huge! That's why I suggest converting stock headlights to relay power first because oftentimes, you may not need anything more.
But no matter what style of bulb you decide on, a relay kit makes life much brighter! I just had my wifes cousin bring me his $75 HID kit he bought off Fleebay from a company called OPT7 and it was junk quality with inadequate wire material, 2 adapters were wrong size, etc. Buy a quality relay kit.
Old 12-10-2014, 01:58 PM   #19
slotard
I'm picking up a pair of JK (07+ Wrangler) headlights for $40 locally. They use H13 bulbs, any suggestions for where to buy a relay kit triggered by the stock bulbs that powers H13s?
Old 12-10-2014, 02:00 PM   #20
gmachinz
I can help you out. PM me if ya want-I've done quite a few of them already for members. I need some info about your charging system first tho.
Old 12-10-2014, 03:28 PM   #21
man7sell
man7sell's Avatar
That sounds like a good way to go Jeff.
I have a couple of spot light relays that came with mt PIA spots on my FJ. I installed factory relays and switches so these were extras. I should try hooking them up to the truck headlights of more V's
Capt. Paul Mansell
1974 Chevy Stepside
man7sell is offline   Reply With Quote
Old 12-11-2014, 08:49 PM   #22
slotard
Picked these up locally today. They're off a Jeep JK, which is what people suggested.
gmachinz, it has an alternator but I'll need to take a look at what alternator it is tomorrow.
1973 C20, 350/350
Old 12-11-2014, 09:18 PM   #23
gmachinz
Cool. Let me know if you need anything!
Old 12-24-2014, 04:50 PM   #24
wideopen1967
wideopen1967's Avatar
Trucklite, I have one of these on my Harley RoadKing, http://www.4wheelparts.com/Lighting-...GNbBoCSejw_wcB
wideopen1967 is offline   Reply With Quote
Old 12-25-2014, 05:51 AM   #25
roger97338
roger97338's Avatar
I put a pair of these (http://www.oreillyauto.com/site/c/de...1576&ppt=C0335) in my '75. They light up the road far better than any headlight in my Nissan or my Caddy...may it rest in peace.
roger97338 is offline   Reply With Quote
