12-11-2014, 09:42 PM | #1 |
Radiator leaking
Looks to be coming from somewhere in front of the fan as the middle section of the radiator and below is wet. It appears to have sprayed on the valve covers. The bottom of the plastic shroud is also wet.
Pinhole leak in the radiator? What's the diagnosis? TIA!
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 Last edited by domano 68; 12-11-2014 at 09:49 PM. |
12-11-2014, 09:48 PM | #2 |
Re: Radiator leaking
Mine was leaking in the same area. I bought a Champion 2 row on ebay from championcooling for Like $169 shipped. Fits great but I had a problem, like others, with the trans lines stripping out in the radiator. So I just got a big aftermarket trans cooler.
12-12-2014, 02:00 AM | #3 |
It's done. Stay away from Champion. Look on RockAuto.com, and get a Spectra Premium. They are very affordable, and top notch.
Don't try Bars Leak radiator sealant. It tends to do more harm than good. You can get some tablets from any GM dealer. They dissolve in the coolant and seal up some surprising leaks. Either way, you are on borrowed time. Order a radiator.
Scotty Baccus |
12-12-2014, 01:49 PM | #4 |
Whats involved in removing and replacing the radiator? Searched youtube and did not find anything related. A step by step would be great.
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 |
12-13-2014, 01:04 AM | #5 |
One of the tranny line end is rusted. I do not want to strip these. So these just unbolt directly and are not flared nuts or anything like that? Any help here would be much appreciated. Thanks.
12-13-2014, 02:12 AM | #6 |
The trans lines should be an inverted flare. Use a flare nut wrench to ensure you don't ruin the nuts.
Drain the radiator, remove both hoses, and overflow hose, if equipped. If you have a plastic shroud, remove two screws in the top edge, two in the lower edge, and a couple on the sides that hold the top half and bottom half of the shroud together. Remove the bolts in the top of the core support that retain the top radiator brackets. Be careful not to lose the rubber pads. Lift out the top half of the shroud, then the radiator. Make sure all the connections match on the new radiator. Sometimes the top neck will be resized using a rubber sleeve. They work fine. Reinstall the radiator, make sure the bottom pads are properly placed, insert top pads, and install the brackets. Reinstall the top half of the shroud, and reassemble both halves, connect the hoses, refill coolant, check ATF, etc...
Scotty Baccus |
12-13-2014, 11:34 AM | #7 |
Now that's a damn tutorial there Scotty. Nice job
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
12-13-2014, 11:55 AM | #8 |
Not to hijack, but what happened to radiator shops. Used to be able to have a leaky radiator repaired. I've got one leaking and can't find anybody to repair it.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
12-13-2014, 12:18 PM | #9 |
You can thank the Environmental Protection Agency for this one.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-13-2014, 01:16 PM | #10 | |
So very true. I can't believe this stuff is still on the market. There is a radiator shop here where I live. He has been doing radiators since water was invented. I would rather replace a 42+ year old radiator than try to have it fixed.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
12-13-2014, 05:04 PM | #11 |
"IF" you want to stay original and a HUGE "IF" there may look at having your original radiator re-cored. MY BIL had the radiator re-cored on his 1957 Chevry station wagon he bought from the original owner who purchased it new in Nov, 1956. Since he is the 2nd owner he wanted to keep the '57 as original as possible. Not a cheap fix but in my opinion well worth the $$ being as he is the 2nd owner of that '57. That also retains yuor brass side tanks instead of getting plastic tanks as with some of the new radiators.
When I had to replace my truck radiator I used that as an opportunity to convert to a 4 core radiator. Takes a little bit of time and upper and lower 4 core radiator mounts but not rocket science at all. Just a thought. Like Lee H stated you can thank the EPA for closing the radiator shops. We used to have three in this little burg, now we have ZERO ! Also EPA closed many of the local chrome shops. You can easily spend $500 & up to get a bumper re-chromed IF you can find a chrome shop that is still open.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
02-20-2015, 10:40 AM | #12 |
Is the green stuff, Prestone, ok to use?
02-20-2015, 10:54 AM | #13 |
The "green stuff" is the only coolant I use. Have it in my '57 Chevy 2Dr, '71 Chevelle, '71 Chevy 4x4, '88 Caprice and our '99 Tahoe. I buy the straight full strength and mix it my-self with distilled water. Hate buying the pre-mixed as your paying for half water in the jug. The Tahoe from the factory used the pink ''Dex-Cool". I drained and flushed it and went with the green Prestone when I had to replace the intake gaskets on the Tahoe, common problem for the 5.7 / 350 V-8. My opinion but I just don't care for the Dex-Cool "jelly-freeze". Have never tried it and don't intend to but have been told DO NOT mix the two coolants.
02-20-2015, 11:34 AM | #14 | |
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
02-20-2015, 12:01 PM | #15 |
I have the spectra premium # A369 in my truck......fits great, cools great....good price!! No problems at all.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
02-20-2015, 03:50 PM | #16 |
My radiator has also sprung a leak. So you guys do not recommend getting the original one fixed? I found a radiator shop that will fix mine for 75 bucks.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
02-20-2015, 06:13 PM | #17 |
I think repairing is fine if the repair tech will stand behind the repair for a while. Understand it's likely a temporary fix. Corrosion, like rust, like icebergs, you only see a tiny bit on the surface. In my neck of the woods it's getting difficult to find a repair shop due to EPA regulations and then it's expensive. Last quote I got for a re-core was $225. For $75 bucks I'd give it a try.
02-20-2015, 06:44 PM | #18 | |
Sorry to hijack the thread also, figured it was better than starting a new one for the sane exact thing
02-21-2015, 12:11 AM | #19 | |
02-24-2015, 11:42 AM | #20 |
GEARHEAD
Aluminum 2 cores are different than the old brass/copper radiators. They are basically twice as thick, so the equivalent of a 4 core.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
02-24-2015, 01:08 PM | #21 |
And they need the four row mounting hardware.
03-06-2015, 03:52 PM | #22 |
exactly! Our cooling rows range 1"-1.25" thick...so even our "smaller" rad cores are still 2-3" thick
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
