12-14-2014, 11:11 AM | #1 |
68 K-10 SWB Step Side Truck Project
68 K-10 SWB Step Side Truck Project. I've been collecting parts for a long time in preparation to assemble this truck and unfortunately I must sell it all. I have too much to list (especially the small stuff) in detail so listed below are major only the components. All parts have been stored inside, some for 15 Yrs+.
I'm asking $2000 obo for everything, which is prices so I can move it all ASAP FRAMEStraight and solid 69 4X4 Frame (set up for a 68 style, E-brake), cab supports have been reconditioned (and are perfect), front & rear springs, fender and bumper brackets. 3.73 rear (I bolted to it to move it around - unknown condition). Trans. mounts (NP 205) and motor mounts (350) incl. Motors: 1. A disassembled (1970) 350 2 bolt mains, heads, crank, cam etc. 2. .30 over 327 block (1968 Camaro), new pistons (flat top Summit L2165 030) already hung on the rods from this engine. Grille and head light assemblies VG condition Core support is rock solid and a perfect rock guard. 67-68 Hood decent condition will need holes patched under where the chrome trim (removed) was. Interior parts from standard trans. Trucks: pedals (2 sets), radio, dash [removed at pinch welds], bench seat, steering assembly and wheel, (non AC) vents, ducts and (2) blowers. All removed from various trucks. Wiring Full harnesses from at least 2 68 SWB trucks LF fender good Cond. has a small section (4”X 5“) above the headlight (eyebrow) to cut out a dent. RF fender Inside steel of the cup need a patch. Both fenders are real solid otherwise. Rear fenders solid as removed from a project in primer. Same with the steps with the exception of a few with a small pin holes. Bed sides are good and straight but will need a bit of work, most notably someone cut a 3" fuel filler hole (driver’s side). Bed front is about perfect Bed Supports A complete set in VG condition the support in the first position support from rear is an NOS part and still has GM stickers. Tailgate is fair condition with a slight bend (I figure about > 1/4" at center) 3 doors 1-67/68 ok shape needs bottom, 2-72's both need the same - can be reworked and would be great for parts for shells. All doors have glass, locks handles and regulators. Fuel tank as removed from a 68 K10 Lights incl 2 VG sets of front and rear (with brackets) and extra sets of front turn signal, hardware and wiring. Lots of other small stuff is boxed and nuts / bolts are bagged and most are labeled as well as some OEM emblems, cables, dash and other parts and pieces. All parts are OEM Last edited by Andrew68; 12-14-2014 at 11:17 AM. |
12-14-2014, 11:42 AM | #2 |
Re: 68 K-10 SWB Step Side Truck Project
Is it a real swb or cut down long bed
olyhotrodz |
12-14-2014, 11:57 AM | #3 |
Good luck. Great price for all this!!
12-14-2014, 12:51 PM | #4 |
It's a real (69) SWB.
The only modifications; I added the under cab E-brake bracket (cable support, correct for the 68), repaired the left side rear spring perch (pocket was punchy), and right side rear spring perch was replaced (previous owner). |
12-14-2014, 05:54 PM | #5 |
interested in rear fenders and steps how much shipped? can you send more pics thanks! zip 29070
12-14-2014, 05:58 PM | #6 |
How much for radiator support, driver door and inner fenders shipped to VA 22801?
67 Chevy Shortbed Fleetside C10 400 SBC/Turbo 350/Posi 62 Impala SS (Clone) 350 SBC/4 Speed/3:36 Posi Rear 2003 Silverado Crew Cab (Black) 2500 HD 4x4/6.0L/Auto/Posi |
12-14-2014, 06:42 PM | #7 |
I'd prefer to sell the entire lot and not part it out. If I do not get a buyer, I will certainly consider selling parts separately.
Thanks, Andrew |
12-14-2014, 06:44 PM | #8 |
Ok let me know if you decide to part it out. Thanks
12-14-2014, 07:41 PM | #9 |
For someone looking for a 67-72 SWB 4x4 this is cheep..... It won't be A matching numbers truck, but it's a real SWB 4x4 frame & parts / component's to put one together. Just price out the parts and you'll see ! Awesome deal !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
09-05-2015, 01:10 PM | #10 |
Do you still have this for sale or any left over parts such as a frame?? Call me at 615-400-1678
