Old 12-14-2014, 10:01 PM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Reupholstered my bench seat.
I started with new foams and spray glued new burlap (walmart was useful for a change) onto them.
Unfortunately the foams I bought were for the comfort package? seat frame. This is the frame that has the springs dropped lower for more foam. I've only ever seen a couple of these seats, and after looking for a few months for a donor frame I gave up and decided to just cut mine (foam) apart. I reshaped it a little better after the pic and glued burlap over it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-14-2014, 10:07 PM   #2
67ChevyRedneck
Re: Reupholstered my bench seat.
Aside from having a good bit of surface rust issues, my frame was in extremely good shape. I hit the surface rust with a wire wheel and scuffed down the rest with a red scuff pad. I put a couple quick coats of rustolium semi gloss on it.
Jesse James
Project "On a Dime"
Old 12-14-2014, 10:10 PM   #3
67ChevyRedneck
I started with the top. I worked it until I got the lines as straight as possible.
Jesse James
Project "On a Dime"
Old 12-14-2014, 10:14 PM   #4
67ChevyRedneck
Then I finished up the bottom today. Bottom was a little tougher as you had to really stretch it.
Also, something I didn't take a pic of, was I did it once and noticed the ribbing for the frame poking the seat material. Not cool. So I removed the front of the cover (only had a few hog rings in at the time) and glued a strip of foam from the old seat along the face. It is visible (was visible with old seat cover too) but at least I know it can't "cut" through. I think my new seat foam was just slightly too small?
Jesse James
Project "On a Dime"
Old 12-14-2014, 10:16 PM   #5
67ChevyRedneck
I had to cut a few holes in the new material (always scary!) and screw the top back on.
Covering up the sides wasn't too hard either.
There's a few very minor wrinkles I'll take my heat gun too when I get time, but for now I have a "new" seat
This IS a project you can do at home. I highly recommend buying the "good" seat cover. They have a thicker vinyl. Sorry, I don't remember the brand, I bought it 3 years ago from Tim Christian. Just take your time, go slow, start from the middle and work your way out.
Jesse James
Project "On a Dime"
Old 12-14-2014, 10:21 PM   #6
67ChevyRedneck
This also isn't my first upholstery job. I think I kinda like it. It's a challenge to get all the wrinkles out and get the piping to work.
My mustang
Before:
After (same seat frame!!!):
Back seat:
Jesse James
Project "On a Dime"
Old 12-14-2014, 11:08 PM   #7
sierragrande71
sierragrande71's Avatar
Seats look awesome man! Great job!
sierragrande71 is offline   Reply With Quote
Old 12-14-2014, 11:37 PM   #8
1968aj
looks good. I had a seat recovered one time . they put too much padding in itand I could barely squeeze in behind the wheel
1968aj is offline   Reply With Quote
Old 12-14-2014, 11:39 PM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: Reupholstered my bench seat.
Yepper's great job there Jessie!
Now are you going to drive it on the 2015 HRPT? That is the question.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-14-2014, 11:55 PM   #10
sduckworth13
sduckworth13's Avatar
That bench seat looks great, you do awesome work.
Scott
sduckworth13 is offline   Reply With Quote
Old 12-15-2014, 08:01 AM   #11
Tropical Snowstorm
Lurky lurky
Tropical Snowstorm's Avatar
Looks awesome, you have a lot of patience, your projects always turn out well. I know what you mean by cutting new upholstery. I just did Katzkins in my DD and had to trim for headrests, armrests, and plastic panels, pretty scary cutting into brand new stuff!
Tropical Snowstorm is offline   Reply With Quote
Old 12-15-2014, 10:40 AM   #12
67ChevyRedneck
Thanks guys. I'm a little sore today. The top was easy because of how far the back "slips over" the frame, you really only need to pull/work the bottom end. I'm a little sore from pulling the bottom cover, then taking the front off to add that extra foam around the face of the frame, then pulling it again.
I had to get my deck project finished up so I didn't get a chance to do the brackets.
Jesse James
Project "On a Dime"
Old 12-15-2014, 02:39 PM   #13
Hart_Rod
Hart_Rod's Avatar
Nice.
Hart_Rod is offline   Reply With Quote
