12-14-2014, 11:16 PM | #176 |
Re: 63 C10 SWB Dropmember Build
Got some time to work on the truck this weekend again, and feel good about the progress made. I was able to get the engine torn down, cleaned up, and new cam installed. I am new to the LS engines, and was good to learn about them by taking them apart. As expected, these engine are quit different than the traditional SBC.
From there, we also got the brake lines ran along the frame, along with the fuel lines. I decided to run SS lines to the master cylinder form the frame. To do this, we did bulkhead fittings in the top of the frame, and will run up to the master from there. I plan on using the new Baer Remaster master cylinder. |
12-15-2014, 01:57 AM | #177 |
60-66 Nut
Coming along very nicely
12-15-2014, 02:33 AM | #178 |
I wish the gas shocks were available when I ordered my hinges too.
truck looks outstanding!
12-15-2014, 01:37 PM | #179 |
12-16-2014, 04:40 PM | #180 |
Nice progress Travis...
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
12-19-2014, 01:38 AM | #181 |
Such a quality build. Great work.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
12-19-2014, 12:21 PM | #182 |
what oil pan is on the motor?
12-19-2014, 12:39 PM | #183 |
Done yet? To bad it wasn't there when I was out or we could've knocked it out!
12-19-2014, 05:29 PM | #184 |
Thank you!
It is a f-body oil pan. Almost! I wish it was done for this last Git-Down, but for sure in 2015. |
01-12-2015, 01:42 PM | #185 |
Been real busy with work lately, and haven't had time told to much on the truck. I did however come across a 1-piece kit for the side windows, and ordered it up today. Should look clean without the vent windows in there.
http://www.classictruckglass.com |
01-12-2015, 02:38 PM | #186 |
Danny 64 C10 SWB fleet |
01-12-2015, 08:23 PM | #187 |
That is a Summit Racing column that my Dad had lying around the shop, and never got used. It could be a little "firmer" felling in the tilt and and mechanics, but overall is nice. I would like to eventually change it out for a Ididit, but works great for now.
01-12-2015, 08:55 PM | #188 |
Truck looks great brotha....maybe you need a engine sponsor with boost!!
01-13-2015, 04:15 AM | #189 |
Thanks man!
01-13-2015, 10:42 AM | #190 |
I'm just glad to be here!
Looking good Travis!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-13-2015, 05:46 PM | #191 |
01-25-2015, 05:19 PM | #192 |
Doyou have any pics of your column mounts? Im not sure how to mount mine
01-26-2015, 01:03 PM | #193 |
i would like to see how the one piece glass looks after you get it installed. i am very interested in doing that to my 63 also.
the Stealth Weapons 63 project, all comments, advice, and critiques welcome! http://67-72chevytrucks.com/vboard/s...d.php?t=438235 |
01-27-2015, 05:40 PM | #194 | ||
Here is some progress from this last weekend. Got the rest of the accessory drive in and the Vintage Air AC bracket and compressor installed. I also managed to get the door aligned as best as possible and installed the PB front core support cross member. Just a lot of little things that needed to be addressed. I got the CaptainFab brake booster bracket installed, and fits awesome! I originally got a 88-98 booster, but was too large (11") and hot the coil pack on the valve cover. I needed up finding a 85-89 Astro Van booster that is about 9" and clears. I am running into this problem due to the drop member raises the engine 2". Normally the 88-98 would have worked. |
01-30-2015, 12:06 AM | #195 |
Trucks looking good! Will that steering column work with a stock steering wheel? Keep them updates coming!
Tony from Norcal |
01-30-2015, 12:33 AM | #196 |
Did you have to buy the Kwik AC bracket separate or does it come with the vintage air kit?
01-30-2015, 12:34 AM | #197 |
01-30-2015, 12:39 PM | #198 | ||
Thanks for the info. I have never tried this, so wasn't for certain. |
02-01-2015, 11:54 AM | #199 |
Great work, that AC bracket looks awesome
02-01-2015, 01:47 PM | #200 |
Badass brotha!
1963 Destiny Build Log |
