Does anybody know?
If my Offenhouser intake and split exhaust manifolds currently on my 292 6 cylinder will fit a 250 6 cylinder or any other displacement inline 6?
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
Re: Does anybody know?
Yes!!
194, 230 and 250 plus your 292. |
That is great news. I have been told that the 250 will get way better mileage.
It might!!
Likely the same though! Swapping to a 250 you need different power steering and a/c brackets. If your 292 is still running good you won't gain a thing. Optimize your timing first. What distributor are you using and what's your initial timing set at? |
Haven't checked timing yet. It has an HEI distributor. So far the compression seems very low and the throttle linkage doesn't allow for wide open throttle. I just got it and am still trying to figure it all out.
I drove it 5 hours home from the purchase with out any major issues but it didn't seem to have much power. The compression is only 85 psi at the highest and 57 psi on the lowest. It will probably need some head work. I was hoping all was good .
How did you check the compression?
Did you hold the carb wide open while you did it? Are you sure it's a 292? You could rotate the carb around and put the linkage at the front and use a bellcrank to get it to open completely. |
Carb wide open. Squirted oil in all cylinders to see if it went up and none did. Then running compression showed lower at idle and higher at rpm. That indicates exhaust valve problems.
Cheaper to put a rebuilt head on it then.
Where can I get one of those?
Your local parts emporium!!
