Old 12-16-2014, 10:12 PM   #1
Gregski
Gregski's Avatar
Rusty's Baseline Dyno Test
Decided to have my '74 GMC 1500 dyno tested before bolting on any shiny performance bits. Rusty is almost all stock except for a few things.
Specs:
350 V8
4 Speed Manual
4 Barrel Rochester Quadrajet
No AC
Modifications:
LMC Truck 2 1/4 dual exhaust with Turbo Mufflers
A.I.R. Air Injection Reactor System - Delete
Here are the results of the three pulls:
1. 172 HP @ 4100 and 259 Tq @ 2600
2. 183 HP @ 4300 and 264 Tq @ 2900
3. 188 HP @ 4100 and 267 Tq @ 3000
* I am eye balling the RPMs for you
This was my first Dyno Test for any vehicle and cost $80 at a place called Evil Genius Racing in West Sacramento, California. John is a super cool guy, if you are local you may want to check them out.
Gregski is offline   Reply With Quote
Old 12-17-2014, 08:31 PM   #2
cadillac_al
Re: Rusty's Baseline Dyno Test
Nice baseline. Aren't these trucks rated at 185 hp anyway? How many miles on yours? Does it rev or pull past 4100 rpm or is that just where max power was? What gear to they test in? I assume 4th or 1:1 gear.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-17-2014, 09:17 PM   #3
y5mgisi
Second Chance Program
y5mgisi's Avatar
Good base!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 12-18-2014, 01:43 PM   #4
gramps77
3 pulls for $80 correct?
gramps77 is offline   Reply With Quote
Old 12-19-2014, 12:54 AM   #5
Gregski
Gregski's Avatar
160 @ 3800 RPM according to the 1974 Light Duty Truck Service Manual, I attribute the additional horse power to the less restrictive dual exhaust and the deletion of the SMOG systems
Odometer reads 34,457 so I am guessing 234,457 as it's hard to put on a ton of miles on a farm truck, probably not much highway driving
Yes it revs passed it, we let off at 4,500 RPM
Good question, I don't know I will have to ask.
Old 12-19-2014, 12:55 AM   #6
Gregski
Gregski's Avatar
Yes
Old 12-22-2014, 04:39 PM   #7
Gregski
Gregski's Avatar
just wanted to share a little trick John did for one of the pulls cause he thought the air cleaner snorkel is too restrictive
I am all about little tricks like that, maybe some of you have seen this done already, but I haven't, yet it is so simple (and yes my air filter is dirty as heck, going to replace it and the air cleaner housing next month)
Old 12-23-2014, 10:25 AM   #8
monte0185
monte0185's Avatar
188hp at the wheels is not bad at all. Remember the old hp and torque specs were done at the flywheel not the wheels.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 12-23-2014, 11:20 AM   #9
Dball
Dball's Avatar
This is what I was thinking, sounds like a healthy base line for sure.
Dball is offline   Reply With Quote
Old 12-23-2014, 11:28 AM   #10
slotard
I'm impressed that it's putting down that much power stock. I ought to dyno mine eventually but with 350/350, 4.10s, and currently 30.5" tires it's no fun on the freeway.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-23-2014, 12:16 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
That's awesome. I need to go have my non-turbo diesel tested so I can have a good laugh.
Old 12-23-2014, 12:42 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
some swear they were made to do that "flip".
but no all fit
sounds louder too,I want to make one stocker a dual snorkel
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-23-2014, 02:07 PM   #13
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
The air filter flip has been around along time. I remember my dad doing it on his '69 El Camino. I did it on my new '77 1/2 ton stepside when I got back then.
If you have a truck with stock exhaust the intake sound when you open it up is far more impressive, especially in the cab.
Happy Holidays and God bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 01-02-2015, 03:44 PM   #14
justcuz
justcuz's Avatar
What I have done is take the snorkel off the air cleaner. It is spot welded on. Them I take a piece of cardboard and trace the oval pattern and transfer one to the other side of the air cleaner and one in the back. Then the air cleaner has three large oval holes in it and retains the breather for the crankcase to the rocker cover. On models that have the breather inside the air cleaner base I just cut the entire bottom off of the air cleaner.
justcuz is offline   Reply With Quote
Old 01-02-2015, 09:48 PM   #15
86c20
86c20's Avatar
nice nubers to start with. but i hope that you dont really think your truck is rusty??? i could show you pix of my c20 and my ramp truck that are on the road and pass inspection that make southners cry lol
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-02-2015, 10:34 PM   #16
Gregski
Gregski's Avatar
Sounds interesting, do you have any pics?
Old 01-03-2015, 09:15 AM   #17
cadillac_al
This power curve is just perfect for the average driving that I do (now). 90% of my driving is between 2000-3000 rpm and the trans shifts at 4500 at WOT. I have to replace my cam this summer and I hope the aftermarket can supply me with a cam with max efficiency at 2500 rpm.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 01-03-2015, 02:04 PM   #18
justcuz
justcuz's Avatar
Yes I think I can come up with a couple later today.
Old 01-03-2015, 09:37 PM   #19
MikeB
MikeB's Avatar
1500-3000 RPM with a max of 4500 (if that much) is where a good driver needs to make power. There are lots of aftermarket cams that will work well for you. The inexpensive Summit Racing SUM-K1101 cam would do the trick, and possibly their K1102 depending on your truck's axle ratio and compression. Some of the newer design cams, like the smallest Lunati Voodoo or Crane Z-series, should work even better.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
