72 chevy modern swap
Well its finally time for a change on the old girl. I've owned my c20 for three years and its did everything a 72 truck should. Shes in need of a face lift and its finally time to do something.
Re: 72 chevy modern swap
nice truck! looks like a nice place to work on it also!
Hey Thanks! its heated and cool does the trick, I have to be pretty happy with it. Built a 12 foot deep work pit that is some what not finished but i thought it was time to try it out.
![]() Join Date: May 2003
So what are your plans for her ? Modern swap ?
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Original plan was to throw a rebuild 350 with a fast fuel injection system on it. With a nv4500 behind that, but i got talked into putting a ls2 insteed.
I've known i wanted to do a swap like this for quite sometime now, but been so busy with work and classes. I started on a lot of small things like gather stuff for fuel system, and getting a transmission together. Here is my fuel tank.
Subscribed.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Thanks Swamp rat! Well been busy tonight, pulled front clip off and yanked the transfer case too.
Cleaned up the np205 last night. Previous owner told me everything was rebuilt at 100,000. Hard to believe when its has 3000 on rebuild and everything is caked in oil.
Back in June i was in search for a nv4500. I asked around, ended up talking to one of my old mans best friend who use to manage a big angus ranch. He told me they have a pickup that had a cab fire, said go talk to the owner. I went over and asked him what he wanted for it, told me 120 would buy it all. Came home with a 95 chevy 3500 with a 454, nv4500, np241, and made 250 in scrap iron from the rest. Wasn't a bad buy at all!
Nice find for the price!
Tell me about it! Money saved on that is going towards an advance adapter kit
Lance Modern 72 k20 4wd http://67-72chevytrucks.com/vboard/s....php?p=6954551 67 c20 2wd http://67-72chevytrucks.com/vboard/s...d.php?t=669589 |
Crossmember showed up today! I've been looking for every way around buying one, but Its not a bad item. Little pricey, but It'll do the trick.
Vintage 4x4s
Subsribed. What hubs are on the truck? They don't stick out very far but aren't spicers...
Good score on the 95!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#15 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Look like selectros Jud. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#16 |
Yes they are selectro's
#17 |
Thanks for the Subscribe too!
Did what i could this weekend, pulled the engine/tranny. I also pulled seat and fuel tank.
#18 |
This summer we were at our local junk yard looking for a 14-bolt posi for my buddy's 67 that I sold him and totally regret selling it. He brought it home, then he realized that he wanted to keep his 4.56s gear instead of 4.10s so i traded him one of my 454s. In return I got the 327 in the truck and the 14-bolt.
#19 |
Sunday I pulled an old running gear out of the trees. Threw some wood on it so I can place my box and cab on when I need to. Also power washed up the frame, going to get the new cross-member laying in there when I can.
#20 |
![]() Join Date: Nov 2007
looks like a fun project. Subscribed! Wish I could have found an NV4500 for $150. Some guys get all the luck.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! ![]() |
#21 |
I have a 92 with a 350/nv4500. The main rear seal is out on the engine. Plan on pulling the trans and use for a later day project.
#22 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice truck, and sounds like a great powetrain choice! Nice shop as well. Are you guys seeing any big snow there yet?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#23 |
Thanks you! Yea yesterday It rained an inch, during the afternoon it changed to snow got like 4-6 inches everything was covered in ice.
#24 |
Tonight I got the bump stops removed so I can get the cross member bolted in right. Got the cross member modified so I can run the other brake line through. I also plan on putting the battery behind the cab so I have to be able to run my cable up.
#25 |
The previous owner must have been quite the rigger using door hinges as exhaust holders,
