12-17-2014, 01:42 PM | #26 |
Re: 72 chevy modern swap
I was curious if anyone could help me out on finding a 6 bolt pattern np205. I know they are like gold and everyone that has one wants to hold on to it. If anyone could help me out on finding one I would appreciate it. If not I will probably end up buying a advanced adapter kit #27-0030. Combining a 10 spline np205 to the 4500, but would like to avoid the adapter all together. Summit racing offers th advanced kit and its cheaper, thinking i will buy it threw summit and save 100 bucks.
Lance Modern 72 k20 4wd http://67-72chevytrucks.com/vboard/s....php?p=6954551 67 c20 2wd http://67-72chevytrucks.com/vboard/s...d.php?t=669589 |
12-17-2014, 03:33 PM | #27 |
6>8 Plugless........
This dude in CO named Ryanroo may have one or know of one. PM him and see if he can help you.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-18-2014, 12:16 AM | #28 |
Thanks Ill see what he says
12-18-2014, 12:49 PM | #29 |
Ha the hinged exhaust hangers made my day! I'm thinking it probably worked really well.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
12-18-2014, 12:50 PM | #30 |
Small modification to the frame, won't weld anything else in tell I no where the lines for the a/c are going. Got a good call yesterday, the specialty shop I work with called me and told me my engine would be here either this weekend or beginning of next week!
12-18-2014, 12:51 PM | #31 |
I was like wow when I got looking, three out of the four were hangers haha
12-25-2014, 12:39 AM | #32 |
Well I haven't posted in about a week. Went north with the old man ice fishing, but got back and went to pick up my present for myself! Its about damn time too.
12-25-2014, 12:47 AM | #33 |
Pulled the harness off, and the manifolds but was taking them off and two of the bolts were snapped off. I managed to spin the one out, but the other may be a challenge. You guys have any ideas????
12-25-2014, 09:12 AM | #34 |
1) Weld a smaller bolt to it. Heat the whole thing up and squirt wd40 on it. Back it out slowly with half turn in. Half turn out.
2) drill it out, use an easy out to extract the bolt. Heat works well here too. 3) trade for a motor without broken bolts. Good luck and Merry Christmas Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
12-25-2014, 11:24 AM | #35 | |
12-25-2014, 11:27 AM | #36 |
The tree had a pretty damn good present under it with my name on it! Also order my advance adapter kit last night! Advanced even had a deal on them!
12-25-2014, 12:37 PM | #37 | |
number three is good too . or just replace with some l92 heads or something! im diggin the column. i have been thinking about doing an aftermarket replacement as well |
12-25-2014, 12:59 PM | #38 |
Looks like a good project here, I like what your doing. Love the shop too! Merry Christmas and happy wrenching in the up coming year.
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
12-26-2014, 09:27 AM | #39 |
Ive tried that on a couple 350s but never worried me because of them being cast iron. Ill give it a shot on the 6.0 and let ya no how it goes
Also curious on standalone harnesses, I will probably end up running electric fans, I pretty sure the factory temp sense stays, but what about the oil pressure??? And if so I need to fine a piece for down by the oil filter because mine had a engine oil cooler on it, but i wont be using that.
Lance Modern 72 k20 4wd http://67-72chevytrucks.com/vboard/s....php?p=6954551 67 c20 2wd http://67-72chevytrucks.com/vboard/s...d.php?t=669589 Last edited by SDfarms; 12-26-2014 at 09:33 AM. |
12-26-2014, 09:35 AM | #40 |
Forgot the pictures!
12-26-2014, 12:22 PM | #41 |
there are a number of places that make block off or delete plates for the oil cooler ports. i think the GM number is 12577903
i dont know the secrets to the stand alone LSX stuff. if you want to use the OEM guage, you will just need to adapt a port into the oil galley for the OE spaghetti line that feeds the guage. if you are swapping to electronic guages, it will probably depend on if they interface with the computer or not. i am assuming the computer needs to see oil pressure to keep the fuel pump relay triggered, but that would depend on how you wired the fuel pump business too. |
12-28-2014, 03:35 PM | #42 |
I plan on keeping the original gauges in the truck, just was wondering if the computer needs to read the oil pressure.
Finally pulled the box off! and in the garage it goes.
12-28-2014, 03:42 PM | #43 |
My god is the back of the cab beat to hell. Looks like I will be doing a little more than I thought. The previous owner must have thought he was quite the rigger.
And does anyone need of a ford bumper?
12-28-2014, 09:43 PM | #44 |
Cleaned up the frame and pulled the rear cross member out too. It needed some work so got it fixed. Going to get the fuel cell in as soon as I can.
12-28-2014, 09:58 PM | #45 |
Had to cut and weld a new end on the 4wd shift handle so i could get my new b&m handle on.
I pulled my rear cover off and thought could it be a 10 bolt posi!?!?
12-28-2014, 10:57 PM | #46 |
Wondering if someone would be able to tell me if it is posi or not?
12-29-2014, 06:05 AM | #47 |
If it looks like this inside it is, Chevy called it a No Spin, but its really just a Detroit Locker. Look inside the little openings.
http://67-72chevytrucks.com/vboard/s...9&postcount=12
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-03-2015, 10:47 PM | #48 | |
01-03-2015, 10:53 PM | #49 |
Im selling both axles, They both have 4.10 gears.
01-03-2015, 10:59 PM | #50 |
Fabed up a behind the cab battery box. I want to clean up the engine bay so trying to get everything hidden and always wanted to put it behind the cab. Ill post the final product tomorrow.
