Old 12-16-2014, 10:34 PM   #1
Dball
Dball's Avatar
How bad is this?
Cleaning up the truck I just purchased a couple of months ago. I took a quick peek at the floors when I bought and they looked pretty solid. Well tonight I started pulling the interior want to recover the bench seat and possibly put in a new carpet kit. Trucks not perfect but looked pretty clean for what it is anyways pulled the door seals and this is what I find
Dball is offline   Reply With Quote
Old 12-16-2014, 10:36 PM   #2
Dball
Dball's Avatar
Re: How bad is this?
Dirty
Old 12-16-2014, 10:37 PM   #3
Dball
Dball's Avatar
Sorry on my iPad one pic at a time
Old 12-16-2014, 10:39 PM   #4
Dball
Dball's Avatar
All of this caked in that one channel
Old 12-16-2014, 10:52 PM   #5
71swb4x4
71swb4x4's Avatar
I don't think it's bad. If it was mine I would clean it all up with a wire brush on a drill. If you have thin spots I would have those small portions replaced. Then I would prime and paint and drive the wheels off it.
I really think what you have is very minor. Are there other spots besides that one next to the seat that seem thin?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-16-2014, 11:05 PM   #6
Dball
Dball's Avatar
Another smaller hole towards the front of the truck. Not really sure how to fix it? I've already cleaned it all up I'll treat it with some kind of rust preventative and POR it.
Old 12-17-2014, 09:58 AM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the holes id go find some sheet metal cut that small area out and patch that weld it in again rust treat the whole area and por 15 it .. where I am that is like mint condition for one of these trucks
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-17-2014, 10:54 AM   #8
Bears63
...just another truck junkie..
Bears63's Avatar
I am amazed you still have that area of your floorboard at all! Around here you just look down and see ground! Clean it up good, patch the open holes and treat it with por15 or something along those lines. You can easily save that floor with a little work so tackle it before it gets worse.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 12-17-2014, 11:12 AM   #9
Speeding Dakota
Speeding Dakota's Avatar
Again being in North East like Old Rusty, that's almost considered NOS (lol). POR-15 has a product called POR Patch that you could use on the smaller holes then cover with the regular POR-15 and top coat you should be good.
http://www.por15.com/POR-PATCH_p_53.html
Good Luck
Speeding Dakota is offline   Reply With Quote
Old 12-17-2014, 11:25 AM   #10
Dball
Dball's Avatar
Thanks guys for the encouragement. I'm located just west of Toronto and believe me we have our share of rust up here as well. I was both disappointed and kind of impressed that's all that I found....on the drivers side anyways, still haven't got to the passenger side yet. Thanks Speeding Dakota I was looking for a miracle in a tube and you found it 😉. I was thinking of some sort of seam sealer I'll give the POR a try. The paints too damn nice and I'm too poor right now to get into a full on body job I'm just trying to slow down the rust where I can.
Old 12-17-2014, 12:22 PM   #11
sgr60
Agreed with all above - it's really not bad at all. Definitely give the POR15 a shot - it's really great stuff, I've used on a couple of projects. And in the places where you it's actually rusted trough, just cut out the hole and weld in a patch - you'll be good as new in no time.
'84 K20 350/465/208
sgr60 is offline   Reply With Quote
Old 12-17-2014, 04:18 PM   #12
Dball
Dball's Avatar
Well I got around to the passenger side today, I have one very small hole in the same area. I did however find an issue with the floor pan. looks like I'm going to lose one layer but it hasn't rotted completely through. I just can't believe that someone before me wouldn't have cleaned this up....said everyone whose ever owned one of these trucks So I'm cleaning everything up the best that I can, I'm going to use POR patch on the holes and then POR the rest of the floor. I was also thinking about either undercoating or using truck bed liner to help with sound? good idea? Lizard skin and dynamat are pricey.
Old 12-17-2014, 06:26 PM   #13
Dball
Dball's Avatar
well my hole just got a little bigger should I continue cutting back the floor to clean up whats underneath? guess its time to start looking for a mig welder.
Old 12-17-2014, 07:31 PM   #14
Axle
Axle's Avatar
Do you weld? If not, now you have a reason to learn.
We (everyone here) are probably the only ones that actually would look. Everybody else sees the nice paint and assumes everything else is as good. That said, my old 83 that I'm stripping down, I have rusty floors, no surprise there that I've kept an eye on, but in taking out the seatbelts, I discovered a very thin spot when I ended up twisting a ring of floor out when unbolting the driverside seatbelt. That was something totally unexpected, bit disconcerting too considering the importance of a seatbelt, especially on todays crowded roads.
Alex.
Axle is offline   Reply With Quote
Old 12-17-2014, 07:41 PM   #15
Dball
Dball's Avatar
Alex.
Actually I'm surprised that's all I found, I'm just not sure about how to address the rot underneath? which looks to be a cab support. I don't weld and will probably have someone put a patch in for me it'll be hard to justify the cost of a welder at this moment.
Old 12-17-2014, 07:44 PM   #16
Axle
Axle's Avatar
Keep an eye on the TSC flyer, they seem to put the little Lincoln (115v flux, and mig capable) on sale once or twice a year for a couple hundred off the regular price. If you have other projects in mind, the welder will pay itself back quick depending on wether or not you have hookups to do the odd welding job for you.
Alex.
Old 12-17-2014, 09:18 PM   #17
74CustomK20
74CustomK20's Avatar
I have a harbor freight el cheapo one and it does good for what I paid (50 used) did my k20, ranger exhaust with it and a couple Biddy's for beer. Its only good for 3/16 at most it says but for thin small stuff its hard to beat.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-18-2014, 12:07 AM   #18
dieseldawg142
dieseldawg142's Avatar
welding patches is not hard, unless you have a tig, or are reeal good at welding & not burning holes, your just spot welding. work your way around the patch spot welding 'till you have a solid weld all the way around. seeing how it's the floor, you dont really need to dress the welds, just level them down with a disc.
or could redneck it & pop rivet or screw a patch over it with some seam sealer to keep out fumes.
personally i think por is awesome
before....
....after
was lucky, only rust hole was by the door bumper. had to buy a replacement rocker for just the curved piece, had to make the bumper bump as it was'nt on the replacement
dieseldawg142 is offline   Reply With Quote
Old 12-18-2014, 12:19 AM   #19
Dball
Dball's Avatar
Nice job, I'm a dumb ass because I had a relatively small split in the floor. I started cutting back good floor because I didn't know what I was looking at. The cab mount below the floor is what's in the worst shape. Live and learn I guess I'm definitely going to have a patch panel welded in. I've done a few pop rivet and roofing tar floor jobs on some older 4x4's it works for what it is.
Old 12-18-2014, 12:22 AM   #20
sgr60
If it makes you feel better, here's what mine loos like. I don't plan on tackling it until the spring - working on the mechanics first over the winter. All just a matter of getting the new panels and welding them in!
'84 K20 350/465/208
Old 12-18-2014, 12:45 AM   #21
Dball
Dball's Avatar
Wow, I still feel pretty good about what I bought I've seen some serious corrosion in the project section. Thank good they make any panel that you'd ever need to fix these things up. Funny out of everything in your picture the worn clutch pedal is what stuck out the most too me. That's some serious heel toe shifting
Old 12-18-2014, 01:22 AM   #22
dieseldawg142
hey, nothing wrong with that
i'm a roofer & some of our work trucks over the yrs get a little thin in the floors, we torch in a piece soprema 250 torch-on down on the floor...
Old 12-18-2014, 10:32 AM   #23
motornut
78K & 79C Jimmys
motornut's Avatar
Yup done those pop n tar patches too.
even self tappers
Even when I'm going to weld them a couple of pops help to hold them in place,creates a good contact too.
I've actually drilled holes for drainage in the floor ,and paint it with tremclad.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-18-2014, 10:59 PM   #24
tomahawk715
If that was for sale here in northern michigan most sellers would advertise it as rust free lol
tomahawk715 is offline   Reply With Quote
Old 12-18-2014, 11:41 PM   #25
old Rusty C10
heres some of my near mind floor NJ and an old cab too far gone by our standards
Bob
I hate cancer!!
