12-19-2014, 01:18 AM | #1 |
Installing new steering linkage.
Started on a little project this evening - I got my new Moog tie rod ends in today, so I started to pull the old stuff to get ready for the install tomorrow. I bought 4 new ends, a new adjusting sleeve as well as a new steering stabilizer.
I started off by pulling the pitman arm to steering arm tie rod. These came off pretty easily, but pulling the first end with the puller was a little shocking - it came off with a real loud BANG! After that one, I was ready with a towel wrapped around the others. I can't remember the last time I did tie rod ends, I don't remember that force on it. Oh well... Old and new: Next, I went after the outers. These were a little harder to get off - the castle nuts were pretty well frozen, and I couldn't get the cotter pins out - they kept breaking. No problem though - just apply some heat from the trusty torch and off they came. If the other ends were bad, these were horrible - completely shot. The steering stabilizer was doing nothing either - the piston juts slid freely in the tube - no compression whatsoever. Getting the ends off the crosslink bar was a whole other ordeal. Those things were completely frozen on there. I was able to get them off with a LOT of heat, penetrating oil, a big wrench, a mallet and the bench vice. Old outer parts removed: Since I will be reusing the cross link bar, it needed to be cleaned up before re-installation. I cleaned all the grease and grime off then sanded and painted it. My impromptu paint station: While the paint was drying and I had the truck up on stands, I decided it would be a good time to tackle the huge amount of grease and grime buildup under the front end (particularly on the drivers side as the PS gear had been leaking for evidently a LONG time). I had tried attacking it with degreaser and a pressure washer - didn't make a dent. So I went at it scraping away all the filth - it was everywhere - core support, front cross-member, frame rail, leaf springs, axle and differential, etc... Here's some of what came off - horrible - After a round of scraping I sprayed on some degreaser and let it soak in. Then I went at it with a bucket of warm soapy water and a scrub brush. What a mess. But, it really helped. I'm going to go at it again tomorrow - should come out a lot better. Will also get the new parts all installed tomorrow after the paint dries tonight. Looking forward to a nice solid steering system!
'84 K20 350/465/208 |
12-19-2014, 01:22 AM | #2 |
Re: Installing new steering linkage.
looking good, keep the pictures coming, love to see projects like this, and you may want to try Mineral Spirits as your cleaner (Home Depot, $5 bucks), I just started using it and it is the best degreaser I have found in 20 years of trying everything from Simple Green to Purple Power to Dish Soap
12-19-2014, 01:26 AM | #3 | |
12-19-2014, 11:04 PM | #4 |
Well, got all the new steering parts bolted up today. The linkage and the new stabilizer are all in!
Got a bit of a start on my new fans as well. Started with some test fitting and got the brackets measured. Will get going in full force tomorrow.
