Old 12-24-2014, 11:08 AM   #1
68Timber
I know the pieces fit
68Timber's Avatar
Front inner fender question
Mine could probably be saved, but LMC lists them for $39.95 for my 79. Not that I'm made of money, but at that price I'm thinking maybe just replace them and put my time and effort into something else. The RF is flaky where it was under the battery and the driver's side has two holes in it where an aftermarket cruise was mounted but otherwise OK. Any downside to the reproductions?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-24-2014, 11:21 AM   #2
Jake Wade
Jake Wade's Avatar
Re: Front inner fender question
The shipping will kill you, unless you live close enough to pick it up.
Jake Wade is offline   Reply With Quote
Old 12-24-2014, 11:40 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
There will also be rust in the area where the fender well bolts to the cab at the back of the opening. I would replace, but as stated the shipping can be a little prohibitive.
Frank
Old 12-24-2014, 11:40 AM   #4
68Timber
68Timber's Avatar
It lists a $20 oversize charge, not sure how much it would be for the actual shipping.
John
74 Honda Z50 build
Old 12-24-2014, 11:47 AM   #5
tucsonjwt
I have no experience with aftermarket fender liners, but all of the aftermarket sheet metal I have seen is thinner than OEM and doesn't line up as well as OEM. Good used OEM liners are available on Ebay but shipping is going to be high however you buy it - unless you buy it locally. Greyhound will ship for usually $50-$70 but you have to drive to a big city station to pick it up. Fed Ex is more reliable and faster to your door for about $20 more.
BTW, the holes for cruise control might be for a cruise control transducer which were a factory option on earlier model years - up to 1982, I think.
tucsonjwt is offline   Reply With Quote
Old 12-24-2014, 12:00 PM   #6
68Timber
68Timber's Avatar
It does have some rust and cracking on the RF on the backside, behind the brace.
I had a 76 w/factory cruise, this was some JC Whitney-type stuff. I'll check the junkyard for inners, maybe I'll get lucky. Thanks.
John
74 Honda Z50 build
Old 12-24-2014, 12:30 PM   #7
piecesparts
I put a set of the aftermarket fender liners on my son's 86 Chevy several years ago and they are still there. Yes the metal is a little thinner, but if you paint and coat them, they seem to hold up well. I did fill a couple holes in his, since we removed the jack and all of the other non-essential items from under the hood, but a little welding, body filler and paint it all looks good. I then coated the underside with rubber undercoat. My advantage is that I live 80 miles from LMC and I can drive to their front door and pick up what I need. They are even open on Sundays.
Frank
Old 12-24-2014, 01:09 PM   #8
77 ChevySport
Any downside to the reproductions?[/QUOTE]
I have never bought or seen them before but if the holes are not drilled from an original one you will have a nitemare trying to install them I would find an original set either from EBay or a junkyard. JMHO Larry
77 ChevySport is offline   Reply With Quote
Old 12-24-2014, 08:36 PM   #9
tucsonjwt
From talking with body men, it depends on your tolerance and patience for aftermarket sheet metal. If you are willing to spend the time to tweak the parts to get proper alignment, and perfect alignment is not your goal, then aftermarket will work out OK. For some, thin sheet metal is OK. For others, the heavier OEM sheet metal is worth the hunt for good used parts. Each to his or her own. For my money, if i am going through the hassle to rebuild the truck, an extra $50-$70 is worth it for the better parts. Good used sheet metal is still available in the desert Southwest - rust free, low cost - just shipping is high which is true for aftermarket also.
Old 12-24-2014, 08:49 PM   #10
tucsonjwt
One more thing about LMC and other aftermarket sellers - read the fine print. They almost guarantee that your parts will arrive banged up and need some work to get back in shape. I am not criticizing them - just pointing out reality when shipping a thin part essentially loose in a thin cardboard box - if any box at all. I have seen them shipped with just a label slapped on the part.
Old 12-24-2014, 09:22 PM   #11
68Timber
68Timber's Avatar
Thanks man, that's why I asked. Hopefully I can find some at the pick and pull better than mine.
John
74 Honda Z50 build
Old 12-25-2014, 09:52 AM   #12
Dead Parrot
About 15 years ago I replaced the driver's side fender with a NOS part and the passenger side with a Taiwan/China part. What was available at the time. The Taiwan part is thinner metal and did have some minor fitting issues but since that the truck has been in two right front collisions, can't really blame the fender. What is apparent after the 15 or so years is the GM NOS part has far worse rust issues then does the Taiwan part. I used the same type of paint and primer(Rustoleum) on both parts.
My guess is despite the thinner metal, the Taiwan part had a better anti-corrosion base coat. Don't know if that still holds true today. Standard disclaimer - small sample size and your results may vary.
This didn't keep me from grabbing an almost pristine driver's side inner fender for $5 and a near perfect radiator core support for $30 at the local pull-a-part. Added bonus was previous pickers had stripped it down to the parts in question so my work was just a few bolts worth. Sadly, the yard folks had used the formerly in near perfect shape outer fender as the support for that corner.
Dead Parrot is offline   Reply With Quote
Old 12-25-2014, 10:51 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
I got aftermarket ones, $50/per ,no fitting issues.
shipped with a sticker, no box,some scratches.
a coat of rust paint,sealed them up.
I didn't fill the holes,or put the jack etc back.
kept the old ones to fix later
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-25-2014, 11:07 AM   #14
68Timber
68Timber's Avatar
John, I appreciate the feedback. If I don't find a good pair at the pick-n-pull I'll go aftermarket. Are yours LMC, and do you remember how bad shipping was?
John
74 Honda Z50 build
Old 12-25-2014, 11:26 AM   #15
Jake Wade
Jake Wade's Avatar
Just go to LMC, put the items in your cart. the shipping charges will be displayed.
Old 12-25-2014, 11:38 AM   #16
77BBGMC
77BBGMC's Avatar
I bought a set a few years ago along with the battery tray from LMC, definitely thinner gauged material but they fit good and serve the purpose well (it's the only after market item I've bought so far that fit but that's another topic). I had mine powder coated so should last awhile.
77BBGMC is offline   Reply With Quote
Old 12-25-2014, 11:46 AM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
When I can wait a bit longer,my auto parts guy eats the shipping.
But he said it came from here.
https://ecat.crosscanadaparts.com/ba...%28FULLSIZE%29
hmm shows the price higher,and now they even come in CHROME?
John
Old 12-25-2014, 12:36 PM   #18
68Timber
68Timber's Avatar
Well, I was going to call them tomorrow, I didn't think about letting the shopping cart calculate shipping. Not bad, $18.75 delivery and handling plus $20 oversize part fee. That's less than I thought it'd be.
John
74 Honda Z50 build
Old 12-25-2014, 12:38 PM   #19
Jake Wade
Jake Wade's Avatar
That's not terrible
