#26 |
![]() Join Date: Feb 2007
Re: 14 bolt Full-Floater Locker Help?
hmm... 3 things.
first, i believe there are only 2 carrier series for the 14bolt and yes the aftermarket thick cut gear sets are for use in the first series carrier but i've never installed or monkeyed with a set so i dont know how much set up deviation there will be. second, when choosing a set of gears for a tire size, remember that we dont use the rated tire size on paper rather use the actual "static load height" of tire which is the actual measurement from the center of the axle shaft to the ground with the tire properly aired and all expected load on the truck. the difference between the rated tire size and the actual load height are very different and there are many variables that change this measurement, ie, wheel/tire combo, air pressure to ensure proper tire to ground contact, vehicle and load weight, etc. Most tires' actual load height is much less than their size rating such as your 40's, they measure out probably closer to 38", not to mention you are actually taking the static load height which is a radius and multiplying that by 2 probably getting you closer to a 37" tire, thus throwing your output values for your cruise calculation way off. This lower tire height value, once found, will compute to a higher cruise rpm speed than what you originally calculated. It's real world vs simulation differences. third, you wont like towing with a rear locker. bangs and clanks of the locker engaging and disengaging while turning will definitely let you know it's back there, as well as tire chirping, accelerated wear with a 40's soft rubber compound will have you rethinking the full time Detroit locker in a towing application. Do you live in a winter climate and will this truck be used to tow in adverse weather conditions and slick roads? AAA? Just some things to think about. I run the Grizzly locker in mine and question my decision from time to time. steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#27 |
I just mention the "thick" gears to try and get out of buying another carrier. I like strength but if I can save about 200 bucks I see no reason not.
As far as towing, it will RARELY be used to tow with in the first place but occasionally will have to. I use my ranger mostly as a tow truck and DD but if the load is too much the big truck gets it. I used it only twice to tow while it had the 12 bolt and 40's... Did OK with the gears but honestly I had to use low every time. As far as actual tire height, you are saying that after its all said and done, I will lose anywhere from 2-4" in height? If so I WILL rethink regearing... Maybe leave it or 4.56's...
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
#28 |
Good news everyone! I could out I have an open carrier, as it has 4... Indention bolts? Or idk how they are pronounced honestly. Anyway I do not need a new carrier and the shop teacher told me that it all looked good gears bearings n all. So I just need my locker.
#29 |
I believe it's called a 4 pin carrier. Tho there are only two, but when you rotate it looks like 4. Once you take the carrier out, take ring gear bolts off and take ring gear off, the carrier will split, then you can take the spider gears out and pins, install the locker and put it back together, essentially. I think there is a " technic" when installed the locker, been years and can't remember. But what's nice bout the 14b locker, wont' have to reset or shim the gears.
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
#30 |
Yea 4 pin... And the tech has a lot of exerience so u trust him. IMA order the summit one n leave the gears alone. He's got the brakes off and will replace them. I'd do it but working 7-12's it just ain't happenin lol
| Bookmarks |
| Tags |
| detroit, locker, tru-track |
| Thread Tools | |
| Display Modes | |
