12-30-2014, 08:06 AM | #1 |
Air fittings and loctite 545
I will be using loctite 545 for my air fittings. Do I need to use anything else?
12-30-2014, 08:31 AM | #2 |
67-72 parts collector,…
Re: Air fittings and loctite 545
No.
Just make sure all the connections are clean and dry before applying the 545. They also recommend a 24 hour cure time for best results.
12-30-2014, 10:20 AM | #3 |
And on the rubber lines use a line cutter so the cuts are straight.
02-10-2015, 08:31 PM | #4 |
Can using too much cause an issue? I had several leaks and the only thing I could figure was that I used too much loctite and maybe it didn't cure properly.
02-10-2015, 08:43 PM | #5 |
I used it and let it cure and it didn't leak one bit.
I also used it (with tape) to plumb my air compressor set up and it worked wonderfully. I like to clean all my fittings. Tighten them once. Completely unscrew them and clean them again. Then I put the sealant on. Put the sealant on the hose, the fitting, compression tube, and top fitting.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
02-10-2015, 08:47 PM | #6 | |
02-10-2015, 09:58 PM | #7 |
I've only ever used Teflon and haven't had any problems.
02-10-2015, 10:52 PM | #8 | |
Or at the tube connection of the PTC fitting? Did you buy DOT approved fittings? Or is this at a combination of NPT fittings? Can youi post pics of be specific where the leaks are?
02-11-2015, 07:17 AM | #9 |
Leaking at the pipe threads. I think I only found one leak at a ptc fitting and that was my fault. All of my leaks were located at the tank. Brass npt fittings and an aluminum tank. I assume that te tank is tapped for npt threads, so all of my leaks were at npt to npt connections.
02-13-2015, 04:38 PM | #10 |
I've heard of issues with home depot brass fittings cracking.
02-13-2015, 05:39 PM | #11 |
You should only be using DOT approved fittings.
