Old 12-31-2014, 09:16 AM   #1
curvedglass
curvedglass's Avatar
turn signal issues
having issues with my 63. the right front turn signal gave out yesterday. Tried a new bulb with the same results. Parking lights come on, rear signal flashes but front does not. light on dash is out for right turns as well. Wiring looks tight. No cracks. Socket is not corroded or damaged.
Any ideas would be appreciated and helpful.
thanks in advance and happy new year to all on the board.
curvedglass is offline   Reply With Quote
Old 12-31-2014, 03:22 PM   #2
Wrenchbender Ret
Re: turn signal issues
The contacts in the switch on those get so they don't make contact. You can carefully bend the copper springs so they contact.
Wrenchbender Ret is offline   Reply With Quote
Old 12-31-2014, 03:55 PM   #3
Micmac
Micmac's Avatar
On my '63 there is only one indicator it operates if you are indicating left of right. Have you ever seen more than one? It used to screw me up when I first got the truck.I know there are many differences in these trucks, even w/i the same model year.
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 12-31-2014, 05:28 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 12-31-2014, 06:18 PM   #5
jtrichard
could be in the switch as stated above OR the bulkhead/firewall plug ......use a test light hooked to the batt. ground and see if you have any power to the socket and the wire..unplug the bulkhead plug and see if you have right turn there
jtrichard is offline   Reply With Quote
Old 01-02-2015, 10:04 AM   #6
curvedglass
It freaked me out too. Made me open up the dash only to find out it only had one light.
The light comes on for the left signals and not for the right. That is how i knew there was an issue.
[QUOTE=The contacts in the switch on those get so they don't make contact. You can carefully bend the copper springs so they contact.
Are you guys referring to the turn signal switch in the steering column?
Old 01-02-2015, 02:05 PM   #7
jtrichard
YES the turn switch
Old 01-02-2015, 02:12 PM   #8
curvedglass
cool. thanks for the tips. going to have to round up a good steering wheel puller. I don't think my wheel has ever been off the column.
Old 01-05-2015, 02:05 PM   #9
curvedglass
I found the culprit. turned out to be a bad connection at the connector to the harness. Jiggled that a few times and the signal turned on and the green indicator lit up. Meanwhile the upper column bearing fell apart and the signal cam has a crack. Ordered up all new stuff. Might as well while it is apart. Thanks to all for the guidance.
