Old 01-02-2015, 02:28 AM   #1
mattwhiteyanks1
deep into my 70 SWB 5.3/4l80-e build
This is my first post on here. I've spent my last few house payments makings Jeff's commission out there at CPP. We're finally starting to head back in the right direction. Drove it in my shop, stripper her down, and it's time to make her new again. 70 chevy truck. It's been in my family all its life. Ps/pb/factory ac truck. Had a 350/th350 in it. That motor will be set aside for a while. I just picked up an 5.3 out of an 04 silverado. Complete with harness, drive by wire assembly, compressor, Ps pump etc. Bolting it up to a 4l80-e. Now for my current questions.... best motor mounts for the trucks(built or bought)? I've heard of "kevs classics" for rebuilding a steering column. I've got my column, but I want tilt, and a cruise control switch of sorts. How can I get a hold of this guy? I hear he does great work. Also, headers...I'm not wanting to spend a fortune, but I do want a quality product and it needs to fit well with the frame and mounts. Any recommendations? I'll post a few pictures of my project shortly.
mattwhiteyanks1 is offline   Reply With Quote
Old 01-02-2015, 02:47 AM   #2
mattwhiteyanks1
Re: deep into my 70 SWB 5.3/4l80-e build
A few photos from my tear down
Old 01-02-2015, 02:50 AM   #3
mattwhiteyanks1
More work. Burning through drill bits, cutoff wheels, and firewood.
Old 01-02-2015, 02:54 AM   #4
mattwhiteyanks1
Feeling like progress at this point
Old 01-02-2015, 02:57 AM   #5
mattwhiteyanks1
Time and money...time and money
Old 01-02-2015, 04:57 AM   #6
scottybaccus
scottybaccus's Avatar
I sell the best mount I know of for a 2wd. I've used them in '73-'87 models, and would love to see how they work in the '60-'72 models.
They align straight up, which moves the transmission forward a couple of inches. With my 4L80e, the mount stud landed in the stock location. My trans cross-member was all the way to the rear. The 5.3 is so much lighter, the fwd position is no issue. My mounts use the OE clamshell assemblies from a late '80s truck. I believe they'll work with your pancake mounts. If you care to try a set, I'll send them out. You can keep the low mount A/C this way. It adds cost to the driveshaft, but saves you the cost of an A/C bracket, and since a driveshaft upgrade is in order, it makes good sense.
I suggest you use Hooker cast iron manifolds. They have the best clearance. Also, get a 2010 Camaro water pump. The lower water neck points lower, and the top water neck is on the driver's side. It requires an inexpensive idler relocation bracket from Dirty Dingo. It will let you use really clean, inexpensive, radiator hoses.
I use a driver side battery tray to clean up and centralize electrical, and free up a path to the passenger side for an air pipe without the space conflict with the alternator and top hose.
I will shortly offer a fan shroud for square bodies. I expect a similar install will work for you. It mounts two 12" GM fans. I'll also have an ecm mount coming soon. Check out my shop page to see how it all fits in my Square. You can message me there.
Tejas Steelworks
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 01-02-2015, 11:40 AM   #7
engineer_gregh
engineer_gregh's Avatar
subscribed. Looks like you are doing a great job. Why is that we TN folks choose to do things like this in the worst possible weather months?
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 01-02-2015, 12:03 PM   #8
mattwhiteyanks1
Thanks for the info Scotty. I'll check that out. As for being a TN man. If I can work in my shop in the winter months instead of being miserable outside, I'm happy to do it. The weather is never awful, but if I've got my options...
Old 01-02-2015, 12:13 PM   #9
engineer_gregh
It looks like you have a nice shop environment to work in, I don't. In Nashville we had 28 overcast and/or rainy days in December. Starting to get me down but enough of that. I have a 71 with the original 307 that I want to do an LS swap with this year. I appreciate your thread and hope to learn from your project.
Greg Smyrna TN
Old 01-02-2015, 12:25 PM   #10
Kennuck
Kennuck's Avatar
Looks good so far. I like how the hidden hitch bolts to the side of the frame instead of the bottom. I have a Boyd's tank so this is what I need. Where did you get it?
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 01-02-2015, 03:28 PM   #11
mattwhiteyanks1
I bought the hidden hitch from CPP. It worked really well. I like how it mounts just right behind the plate. As for my ls swap. It may not be the best way to do everything. Certainly won't be the most expensive or elaborate, but this truck will be done right. I'm excited about this one. It's actually my grandfather's truck. I'm just building it for him. Has a lot of history being in my family it's whole life
Old 01-03-2015, 01:40 PM   #12
C10agent
C10agent's Avatar
Subscribed- sweet looking truck and killer progress so far!
Neil...............
1972 C10 SWB - Shop Truck in the Works
5.3 LS / Full Air Ride / Rear Notch
20" American Racing Daytonas
IG - neilioustx - pictures of build/progress
Born and Raised in the Promised Land....
TEXAS Y'ALL!!
C10agent is offline   Reply With Quote
Old 01-03-2015, 02:01 PM   #13
mattwhiteyanks1
The fuel tank from LMC came in today. Tank looks good and fits fell. However, only two bolts for the two straps holding the tank. Not sure what the deal with that is. No instructions nor were there any diagrams.
Old 01-03-2015, 03:29 PM   #14
mattwhiteyanks1
Thanks Neil. Working on cleaning up my wiring harness and getting the motor cleaned up as well today.
Old 01-04-2015, 11:13 PM   #15
mattwhiteyanks1
Installed the blazer tank today from lmc. Came with two straps, but only two bolts. Not sure what the deal is with that. No diagrams, no instructions. Otherwise, it fit's well. Set the cab down for the first time since I did the frame work and suspension upgrades. I'm liking the look so far. Hopefully I can mock fit the motor and transmission in the next couple days.
Old 01-04-2015, 11:15 PM   #16
mattwhiteyanks1
Hopefully I'll get more of my parts in, now that the holidays are over. It seems to put a 4 week delay on ordering anything
Old 01-06-2015, 01:15 AM   #17
mattwhiteyanks1
Progress has felt slow lately. Strated working on motor placement and making my mounts.
Old 01-06-2015, 01:35 AM   #18
mattwhiteyanks1
How to I move this post to the build thread section?
Old 01-06-2015, 09:00 AM   #19
67 chevelle
67 chevelle's Avatar
http://www.ebay.com/itm/1963-66-68-6...b16b8a&vxp=mtr
I would give these a try , the performance online mounts work also,, but move your engine forward 1 1/2 to 2 inches
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 01-06-2015, 10:31 AM   #20
Nohassle5
Nohassle5's Avatar
Subscribed
71 C-10 Suburban (In Progress)
70 C-10, Short & Wide SOLD
64 C-30, Custom Dually Cummins 12V SOLD
Nohassle5 is offline   Reply With Quote
Old 01-07-2015, 02:52 AM   #21
mattwhiteyanks1
Picked up a radiator and electric fan assembly today. I'm going to change the support a bit so it sits closer. Even the stock set up sits too far out for my liking. I don't know why they didn't tuck it in better (maybe for easy removal and install?). A lot of room can be saved by moving it into the support. Anyways, far from done but it's starting to take shape and I'm going to have much more room between the motor and radiator now.
Old 01-07-2015, 10:41 AM   #22
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Looking like a good build. Keep up the good work. I'll be following this one. Subscribed.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-11-2015, 12:06 AM   #23
sleepertruck72
sleepertruck72's Avatar
Nice project, nice work
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-11-2015, 12:20 AM   #24
mattwhiteyanks1
Got the fuel pump, sending unit, and regulator hooked up. Cut the radiator support here and there (so I can fit my 2006 radiator and dual electric fans in). Wanted a tighter fit and it saves room as well. Not done with it yet, but it's getting there. I'll get the motor mounted this week hopefully. I put the hookers on the other day. I like the old school look of them. Thanks for following
Old 01-11-2015, 12:23 AM   #25
mattwhiteyanks1
Started porting and polishing the throttle body as well.
5.3, build thread, swb
