Can this be fixed?!
I just picked up a 72, C-10 with air ride.
But the right side bag was not working. Jacked it up and found this!! ![]() Anyone have a spring mounting plate?? |
![]() Join Date: Nov 2001
Re: Can this be fixed?!
Oh My God... and I thought my truck was rusty.
I think you will be looking for more than a mounting plate. Look at that trailing arm...? ...and welcome to the board!
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
The other trailing arm looks worse.
The frame will need a little welding, guess I need a spring mount plate? ![]() |
Junior Member
Omg!
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
#5 | |
No Limit has a back-half kit (raised rail) if you were planning on dropping the truck which essentially replaces the frame from the trailing arm crossmember back but cost is about $1100.00 and it will take a lot of skill to get it right. An alternative is to shop for a new frame from the local junkyards. Here in AZ they are available for about $750-1000 but you have to pick it up. |
Is the frame rail supposed to be push up against the wood floor?
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
If it were me I think this would be a parts truck or would require a parts truck. Trucks of this era were slightly overbuilt, but they had slide rules. There's not an abundance of extra structural steel back there, and most of what you have appears corroded.
Just because something doesn't have a hole in it doesn't mean it's not weakened. Sorry to be the bearer of bad news, but I think you've got some serious safety concerns there. Others might have faced rust like that (I'm from the Midwest and that's a lot to me) and be less pessimistic or have tips on how to proceed.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
What the rest of the truck looks like would determine if it is worth fixing.
It all comes down to how much time, money and mechanical ability you have. If the rear looks like that i bet the front end isnt much better at all. It might be better to get a new frame or make your new truck a parts truck. Is the body, interior and motor good? If they are nice i would swap the frame if they need work too i would use it for parts.
I wish I was rich instead of so damn good lookin!! |
#11 | |
![]() Join Date: Aug 2013
I think it would be wiser to take the good parts off and put them on something solid. Since yo are from MO. I am sure you can find something much, much better at a reasonable price. Jim |
Stalker Nate
Looks like a parts truck. I hope the body is more solid than the frame or you got the truck for $400 as then you can take the good parts & scrap the rest. Deff need to see a full photo but that entire backhalf is gone & not safe or road worthy.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
The front half of frames seem to hold up pretty good. The rear gets it all thrown back at it and air flow, oil leaks, and flung grease do wonders for a frame's complexion. Sorry about your luck, this one's roached. Is it a shortbed or longbed, can't quite tell. I can't believe someone put bags on a frame like that. Just go on with it, I guess
![]() Join Date: Sep 2010
I think your easiest and cheapest way to fix this is a different frame...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
#15 |
It is a 72 blue long bed withwood floor
Air bags front and rear. The cab was fixed 10 yrs ago so it's starting to get some bad spots, but pretty solid. 383 stroker and the stock saginaw 3 speed. May be parting it out, THE MOTOR IS MINE!! Pic's soon. its dark now. |
#16 |
![]() Join Date: Aug 2008
WOW. Air ags on a junk frame. Also...saginaw 3 speed was never intended to stand up behind a 383...what were they thinking???
#17 |
Holy Toledo, Columbus Ohio.
U need a new frame under that bad boy. Too bad you are soo far from AZ. About $300 here will buy you a straight rust free frame. Heck a guy I know has a roller complete with a 6 cyl. motor for $350. Rust YUK.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#18 |
holy crap... that's sketchy, new frame all the way. If that's the back half of the frame, who knows what else is compromised... and the air ride is only going to make it worse. if the body is clean... then you need a frame donor for sure.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
#19 |
![]() Join Date: Feb 2012
yes you can fix that
#20 |
Here is the rest of the truck.
It has a brand new re-pop tailgate still in primer, 5/4" decking wood bed Someone posted it was a $400 truck, Really? ![]() ![]() ![]() |
#21 |
Yes it can be fixed...hell anything can be fixed! If your in $400 then your at least $19,600 better off than a lot of guys on here. Take your time find good people locally to help you out and enjoy that ole thing.....
#22 |
I didn't pay $400.....I paid less.
It will be a nice cruiser, got a frame guy (does back halves and stock cars) He will fix me up. And it will be faster with a lighter wallet. ![]() ![]() I need trailing arms and a stock seat... |
#23 |
![]() Join Date: May 2013
Post pictures along the way , when repairing , we love that stuff . Your truck looks great ,,,,,,from above,,,,, even putting on a lift would scare me , but if the front half of the frame is solid """which I doubt'''''' you could weld in the back half from a doner ,,,, new frame would be better ,,, there are tons of them around but lots of rust in your area
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#24 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Yep, I'd get a different frame. If you lived around here (or come down on vacation) I have a perfectly good LWB frame I'd let you have for free.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#25 |
Holy crap, I've seen NY trucks with better frames.
I'd have a hard time believing the front doesn't look just as bad? Check inside all of the areas where all the cross members connect to the fame, they're notorious for rotting out there too... and if the back half is that bad...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
