Old 01-05-2015, 12:40 PM   #1
inkslinger1964
alternator
1964 chevy c10 with 283. New alternator and still does not seem to be charging battery. hooked up meter to battery and had 12.9 volts. started engine expecting it to rise and it fell to 12.5.
inkslinger1964 is offline   Reply With Quote
Old 01-05-2015, 01:16 PM   #2
PGSigns
PGSigns's Avatar
Re: alternator
Have you checked the voltage regulator for function and wiring issues?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-05-2015, 10:22 PM   #3
Hugh in NC
Hugh in NC's Avatar
Re: alternator
I installed a new alternator on another type of vehicle and had the problem of intermittent charging. Returned new alternator and exchanged for another, same problem. After 3 days of tinkering, I found the brand new shiny powder coated bracket was not grounding the alternator. Put ground wire from alternator to block and everything perfect. Try a ground wire.
Hugh in NC is offline   Reply With Quote
Old 01-06-2015, 11:22 AM   #4
inkslinger1964
Re: alternator
i will try that
Old 01-09-2015, 03:56 PM   #5
Pappyx3!
Pappyx3!'s Avatar
Re: alternator
Did you figure out the problem? Does it have an internal or external regulator?
Pappyx3! is offline   Reply With Quote
