Closed Thread
Old 01-07-2015, 12:29 AM   #176
1948GMC
1948GMC's Avatar
Re: What did you do with your truck today, take 2
Slowly gathering parts for my 383 stroker and building it. Have short block assembled and waiting on new valve springs, oil pump, intake, carb, valve covers, fuel pump, water pump and much more.
1948GMC is offline
Old 01-07-2015, 01:02 AM   #177
capnduane
capnduane's Avatar
I'm down to just little fixits, and trying to upgrade and improve the looks under the hood. Really miss the action of restoring the old truck when I first got it! Man, I remember the thrill when I first got the lights to work!! This weeks project wasn't much, but replaced the heaterhose (actually a bypass from the waterpump to the block) as its not hooked up to the heater. This is So Calif, don't need no stinkin heater Ha! The ugly old red hose ran up and over the right side of the intake manifold and looked like shat. Ran a new black hose down along the frame and kinda outa site.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline
Old 01-07-2015, 03:24 PM   #178
yoshi
yoshi's Avatar
Bolts for starter motor arrived along with exhaust parts. I need to modify my exhaust to go round the brake booster, i could of got 4 45° bends or buy this kit. I'm gonna cut the flanges off then weld these in, it means half the amount of welding & i haven't got to mess around with angles
yoshi's 49 project
yoshi is offline
Old 01-07-2015, 07:01 PM   #179
Stevetoxic
Stevetoxic's Avatar
Over the last couple of weekends I've been swapping the original springs for a set (F+R) of Posies Superslide 3" drop springs.
Then I decided I did'nt like the Chrome wheel/white band tire combo I had, so now using a set of old 7x15 day van wheels painted black with 235/75x15s all round.
Looks better - but I gotta get me some power steering !
[IMG]DSC_0074 by SteveToxic, on Flickr[/IMG]
Stevetoxic is offline
Old 01-07-2015, 08:03 PM   #180
oldman3
oldman3's Avatar
Welcome to the forum. Nice looking ride...Jim
oldman3 is offline
Old 01-09-2015, 11:32 PM   #181
OrrieG
OrrieG's Avatar
Got my goodie box from Vintage Air and Classic Parts....
OrrieG is offline
Old 01-10-2015, 11:51 AM   #182
AZ59apacheguy
What is that hose for coming from the front passenger side of the intake manifold??
AZ59apacheguy is offline
Old 01-10-2015, 03:35 PM   #183
capnduane
capnduane's Avatar
I think you must mean the pcv hose that comes up from the pcv valve in the valley cover at the right front of the engine and goes into the base of the carb?
Old 01-11-2015, 07:21 AM   #184
57chevyman
57chevyman's Avatar
new air cleaner
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline
Old 01-11-2015, 08:27 PM   #185
57chevyman
57chevyman's Avatar
New radiator hose.
Frank
1957 Chevy 3100
Old 01-11-2015, 10:51 PM   #186
AZ59apacheguy
Huh, I don't think I've ever seen one coming from the intake like that. Did you drill out the intake to accommodate your PCV setup?
Old 01-11-2015, 11:55 PM   #187
OrrieG
OrrieG's Avatar
It is a Pontiac engine...
OrrieG is offline
Old 01-12-2015, 03:17 AM   #188
capnduane
capnduane's Avatar
Not the best picture.... If you look closely you can make out the pcv valve with the black hose attached to it and secured with a zip tie. This is a 400 Pontiac engine and unlike the Chevy V8s, has a separate sheet metal cover over the lifter valley. The hole is in this cover.
Old 01-12-2015, 10:57 AM   #189
AZ59apacheguy
Wow, cool. The Chevy valve covers threw me off. What size is it?
Old 01-12-2015, 01:09 PM   #190
capnduane
capnduane's Avatar
Its 400 cu in., came out of a '69 Firebird. has some kind of hi lift cam and a Edelbrock carb on a Holly manifold and dual exhaust with glass pacs. Around 325hp? This engine was in the truck when I bought it, it runs strong, but I suspect it has been around a long time.... So I just cruise, hardly ever get into the secondarys! The red color kinda makes it look like a Chevy at first glance
Old 01-12-2015, 01:19 PM   #191
AZ59apacheguy
Man, different is coooool. Everyone's dropping 350's, LS and BBC into these trucks. Nice to see something different. What is the motor mounts look like? Does it mount up like a SBC, or does it have a different system?? Thanks
Old 01-12-2015, 01:27 PM   #192
capnduane
capnduane's Avatar
The guys that installed the Poncho in my pickup did a good job. The engine has mounts on the sides of the block and they fabbed a C channel cross member for them. Then another crossmember at the tailshaft of the Muncie trans. The stock crossmember and front mounts are still there for the original 265 V8, so it could be switched back if someday someone wanted to return the truck to original. Its kinda cool to have the Pontiac engine, not something you see everyday....
Old 01-12-2015, 01:54 PM   #193
OrrieG
OrrieG's Avatar
Got the AC condenser and dryer installed, next is making up the lines.
OrrieG is offline
Old 01-13-2015, 01:41 PM   #194
thebebop
thebebop's Avatar
Started the brake lines today...
1955 2nd Series Truck
thebebop is offline
Old 01-15-2015, 08:07 AM   #195
Michel
Michel's Avatar
Have finally received my rims from the US and have the new tires installed.
[IMG][/IMG]
Need now to order some new lug nuts...
'55, Chevy 3600, 2nd serie, 3/4 ton, 235, 4 speed Muncie SM420, 4.57:1 rear axle
Michel is offline
Old 01-16-2015, 05:43 PM   #196
57chevyman
57chevyman's Avatar
Did my steps with spray on bedliner
Frank
1957 Chevy 3100
Old 01-16-2015, 10:34 PM   #197
OrrieG
OrrieG's Avatar
Started on the AC lines. Right tools make it easy....
OrrieG is offline
Old 01-16-2015, 10:39 PM   #198
57chevyman
57chevyman's Avatar
New tool box
Frank
1957 Chevy 3100
Old 01-17-2015, 07:53 PM   #199
MIKESAD50
Got my cab off to a friends house to have the floor boards replaced and he talked me into replacing the firewall also even though it just needs holes filled going smooth.
trying to talk me into going all out with body and paint instead of leaving the body the way it looks.
1950 3100 5 window
MIKESAD50 is offline
Old 01-18-2015, 06:03 PM   #200
OrrieG
OrrieG's Avatar
Found out my AC compressor came with an odd ball head piece that I cannot find fittings for (1" x 14). Will need to swap it out for a K type head that will take standard #8 and #18 fittings.
OrrieG is offline
Closed Thread
