Old 01-08-2015, 06:28 PM   #1
greenmonsterC20
greenmonsterC20's Avatar
The 383 stroker so far for my 69 C20
.030 over 1969 010 four bolt main block with ARP main studs
SRP forged short skirt pistons
6 inch Eagle SIR rods
Stock 400 crank
Melling high volume oil pump
Lunati nitrous cam .520/.509 lift with 234/244 @.050 on a 112 LSA
Canton 7 quart oil pan
Moroso Re-enforced timing cover
69 C20 3/4 Ton 350 TH400
63 Buick Rivera 407 Nailhead TH400
greenmonsterC20 is offline   Reply With Quote
Old 01-08-2015, 08:03 PM   #2
67 chevelle
67 chevelle's Avatar
Re: The 383 stroker so far for my 69 C20
Thats alot of cam ,,,,, what heads
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-01-2015, 12:39 PM   #3
greenmonsterC20
Dart sportsman 200 cc runners, ported, 2.055 & 1.625 valves.
Old 02-01-2015, 02:45 PM   #4
coopdog
coopdog's Avatar
I must have started a trend! I put dart heads on my 350 small block
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 02-01-2015, 03:50 PM   #5
SierraMtns
SierraMtns's Avatar
Stock 400 crank
Attachment 1346437
Attachment 1346438
WOW....looking good.
Whats your HP goal?
SierraMtns is offline   Reply With Quote
Old 02-02-2015, 09:16 AM   #6
67 chevelle
Excellent choice for heads , should work great with your engine
Old 02-02-2015, 01:04 PM   #7
Molberg
Molberg's Avatar
That's almost the same cam/set up I'm runnin. I chose AFR heads for my rig. Can't wait to hear it rumble. AFR has dyno sheets around the 475 hp mark with that setup. Good choices there IMO.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 02-03-2015, 08:17 PM   #8
cleszkie
cleszkie's Avatar
Are you running a flat tappet cam? I'm assuming so based on the block. Why not a roller cam to go with all of the other goodness you've assembled? Not knocking your set up, just curious.
cleszkie is offline   Reply With Quote
Old 02-03-2015, 10:18 PM   #9
Crabass
What does it cost (if I might ask) up there in Illinois to have the mains honed for the studs?
Crabass is offline   Reply With Quote
Old 02-04-2015, 09:58 AM   #10
adricar1
Line boring?
have you measured the bores on the main bearing saddles? measure them with the bolts torqued up and then with the studs , if there is a difference then get it line bored, more than likely there will be no difference.
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
Old 02-15-2015, 05:59 PM   #11
greenmonsterC20
I figured i will run this flat tappet until i get tired of it. I will put a roller cam in when the engine comes out of the truck for a freshen up.
Old 02-15-2015, 06:02 PM   #12
greenmonsterC20
Whats your HP goal?
We're thinking around 440 hp and close to 500 ft lbs.
Old 02-15-2015, 06:04 PM   #13
greenmonsterC20
Originally Posted by adricar1 View Post
Line boring?
The mains were twisted from the studs, no line boring, but a line hone was recommended. Only ran me 100 bucks.
Old 02-15-2015, 07:17 PM   #14
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Nice! What tranny and rear end?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-15-2015, 09:38 PM   #15
greenmonsterC20
Doug Nash 5 Speed, and a Dana 60.
Old 02-15-2015, 09:39 PM   #16
greenmonsterC20
Truck currently has a th400 and a Eaton HO72. Nash and Dana are being built.
