Alternator question
Still running down parts for my Ls swap into my 85 c10. Not sure if it matters but it's going carb'd. Is there a way to have a straight plug and play alternator. I have seen that the alternator for the 5.3 doesn't have the correct connection. Can I run the old alternator with the 5.3 and everything hook right up?
Re: Alternator question
I just wired the "L" terminal to the alternator warning light wire and left the other three unhooked on my '72 with a stock 4.8 alternator. Worked fine.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
meowMEOWmeowMEOW
Fbody 1-wire alternators can be made to fit on the truck brackets, but still have to be modified slightly to work.
What is the issue with the 3-wire setup, do you not want to run it to the ecm?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
From what I have read online I assumed the genIII alternator want work with my c10 wiring harness. I want be using the harness from the 5.3 since I'm going carb'd. I assume that connection on the 5.3 alternator will be different from my c10's connections
#5 | |
Old member
![]() Quote:
The connection them selves maybe differant phiscally but it can still work by using butt connections I would think. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
You can utilize a truck style alternator, one wire hook up with the c10 harness. All you need is the constant 12v to the lug and the key on 12v to the plug (can't remember which terminal) It'll require some resistors inline, 470-480ohm iirc. I'd run the truck alternator, they come in a bigger amp than the fbody alternators. Ls1tech has tons of info in the lsx swaps sub forum.
#7 | |
![]() Join Date: Jul 2009
For what it's worth, the 2 pin regulators require a PWM (Pulse Width Modulation) signal from the ECM to operate properly. Pretty much all the Gen IV engines (car or truck) have this style of alternator/regulator. If you already have an alternator with a 2 pin regulator, I posted this how-to on swapping out the regulators on the trifive board a while back. It'll set you back about $20, but that's cheaper than a new alternator: http://www.trifive.com/forums/showpo...62&postcount=1 |
I'm Confused about what you all are saying.
I've done four or these swaps and all I did was hook my 12v alternator wire from my harness to the LS alternator and hook up the starter wires from my harness to the LS starter. The other connector on the alternator goes to the ECU. Am I missing something? My 78 Z28 has been running like that for two years. |
#9 | |
