Old 01-11-2015, 07:09 PM   #1
Blanco
Tejano 52
New project please feel free 2 comments on the build I'm not in any way an expert at this but just like to do wrenching
Blanco is offline   Reply With Quote
Old 01-11-2015, 07:19 PM   #2
Blanco
Re: Tejano 52
Name:  2013-12-28 16.45.28.jpg
Old 01-11-2015, 07:26 PM   #3
Blanco
Re: Tejano 52
the truck was a complete truck the entire drive train was there has some rust in the usual places corners floorboards
Old 01-11-2015, 07:29 PM   #4
Blanco
Re: Tejano 52
got the truck home and immediately started to take it apart
Name:  2014-03-18 18.59.52.jpg
Old 01-11-2015, 07:33 PM   #5
Blanco
Re: Tejano 52
got some new tires mountains in on some old wheels that I had
Old 01-11-2015, 07:34 PM   #6
Blanco
Re: Tejano 52
I'm hoping that the truck will have a low stance and will end up something like this
Old 01-12-2015, 03:27 AM   #7
CMFT
CMFT's Avatar
Re: Tejano 52
Looks like you're off to a good start. Nice to see another local build.
'58 Apache
CMFT is offline   Reply With Quote
Old 01-12-2015, 07:17 AM   #8
Blanco
Re: Tejano 52
Old 01-12-2015, 09:02 AM   #9
mikec4193
mikec4193's Avatar
Re: Tejano 52
Hi Blanco
What are the plans for the truck?? Are you keeping the original 6 cylinder and the 3 speed transmission?
I am loving the looks of the original finish on your truck.
Is Tejano the name you have given the truck?
MikeC
mikec4193 is offline   Reply With Quote
Old 01-12-2015, 07:52 PM   #10
Blanco
Re: Tejano 52
yeah I plan on keeping the truck with the same look the original 6 cylinder and the transmission have been removed and dumped I'm planning on putting a 283 na 400 transmission I will post pictures later
Old 01-12-2015, 07:57 PM   #11
Blanco
Re: Tejano 52
This is what it looks like now
Old 01-12-2015, 08:00 PM   #12
Blanco
Re: Tejano 52
if anyone has ever used one of these black cross members please let me know where do you both get on I'm not a hundred percent sure and I've done some measurements I don't want to make any cuts or make any hold until I'm 100 percent sure
Old 01-13-2015, 09:02 AM   #13
Katrina/10
Katrina/10's Avatar
Re: Tejano 52
I have used one of those crossmembers before and would like to help, but I don't understand your question.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-13-2015, 08:02 PM   #14
Blanco
Re: Tejano 52
I just really have questions on where to bolt the crossmember at. How did you install yours, did you measure from the front of the frame or from the firewall forward?
Old 01-13-2015, 08:13 PM   #15
Katrina/10
Katrina/10's Avatar
Re: Tejano 52
It doesn't really matter where you measure from. I bolted the crossmember to an empty engine block and trans case, then moved it back and forth till they were where I wanted them. You will probably have to trim the ends off the crossmember, and move your steering box.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 01-13-2015, 11:39 PM   #16
Blanco
Re: Tejano 52
do you have any pictures of what you did to your truck that maybe I could seethanks for the help with this
Old 01-14-2015, 02:19 PM   #17
Katrina/10
Katrina/10's Avatar
Re: Tejano 52
No, don't have any pictures, that was a long time ago. It will be pretty obvious what you have to do if you can test fit the engine.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 01-14-2015, 03:10 PM   #18
Blanco
Re: Tejano 52
Cool thanks going to try it this weekend
Old 01-14-2015, 11:03 PM   #19
Advanced Design
Advanced Design's Avatar
Re: Tejano 52
Yep, when you position the engine and transmission in place (in the up and down plus fore and aft planes) you will see where that crossmember needs to go. Looks like it will need trimming to fit the frame.
Good luck and have fun.
Advanced Design is offline   Reply With Quote
Old 01-17-2015, 10:57 PM   #20
Blanco
Re: Tejano 52
started to do the mock up today hopefully tomorrow I will have the engine installed
Old 01-18-2015, 02:25 PM   #21
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Tejano 52
Beautifully freshly painted engine and new cross member, are you gonna clean up the frame and paint? No time like the present, "While you're in there"!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 01-18-2015, 03:24 PM   #22
Blanco
Re: Tejano 52
yes definitely I want to paint the frame at this point I'm just working on the mockup once it's all in place I will remove the engine and paint the frame
Old 01-18-2015, 10:25 PM   #23
Blanco
Re: Tejano 52
got the engine marked up
Old 01-18-2015, 10:27 PM   #24
Blanco
Re: Tejano 52
and still have some room in the back
Old 01-18-2015, 10:59 PM   #25
Blanco
Re: Tejano 52
going to put in the transmission tomorrow and make sure all of it is in place so that I can paint it black
