Old 10-20-2014, 06:04 PM   #1
Daveiaff
1972 Suburban air bags front project
Started this last week. Ordered new ball joints top and bottom. Have the cool ride front kit from air ride tech. Thinking of getting drop spindles now so I don't have to remove spindles later. Has any one used the air bags with the drop spindles? I'm getting the 2.5 inch drop. Brand recommendation?
Having problem uploading pics. Will try later.
Daveiaff is offline   Reply With Quote
Old 10-20-2014, 06:11 PM   #2
Daveiaff
Re: 1972 Suburban air bags front project
Cleaned up with bump stop removed.
Old 10-20-2014, 06:39 PM   #3
Number98
Prestige Worldwide
Number98's Avatar
Looks good, welcome to the board and glad to see another Burb!
Number98 is offline   Reply With Quote
Old 10-20-2014, 07:19 PM   #4
Daveiaff
Before removing bump stop.
Old 01-12-2015, 08:07 PM   #5
Daveiaff
A little rust on the passenger side floor turned into inner and outer rocker, part of floor, toe kick and the part that goes below the bottom door hinge. Lots of fitting, but fun to MIG weld.
Old 01-12-2015, 08:17 PM   #6
Daveiaff
My favorite pic, pile of old stuff, pile of new stuff trimmed to fit.
Old 01-13-2015, 08:03 PM   #7
rskuared
Hey Daveiaff,
I'm also starting on '72 Burb. Considering using Accuair Stage 2 e-level kit, color ride front
and rear and cool ride shocks. My biggest obstacle is notching the frame. Do you have any thoughts on this? Is it worth the hassle? Thanks.
rskuared is offline   Reply With Quote
Old 01-16-2015, 08:32 AM   #8
Daveiaff
When the rear bags are down on mine the axle is touching the frame. I'm going to notch the frame myself with some pipe and plate. I've repaired rusted frames in the past, so I have experience with stick and mig welding. There are bolt in kits out there, but I'm going for a cleaner look. As mine sits now it is level. When I get the drop spindles, I'll match the C in rear frame to match, I just have to make sure there is some drop left in the air bags. I don't want to go with a larger c, the wood floor is in great shape and I don't want to disturb it. Also the fuel lines run down the passenger side of the inner frame on a burb , so that is another step that wouldn't apply to a truck c notch
Old 01-17-2015, 07:06 PM   #9
5150
C10 Club Tennessee
5150's Avatar
Dave, to get a little lower you should cut out the cup on the lower control arm.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-10-2015, 06:02 PM   #10
Daveiaff
Parts burb. Excellent barn doors. Runs and stops. 350 4 bolt mains.
Old 04-10-2015, 06:06 PM   #11
Daveiaff
On bags all 4 corners. Drop spindles are in, just have to install. Photo in above post is one that I found 2 hours away. Picked up today.
Old 04-10-2015, 06:54 PM   #12
Advanced Design
Advanced Design's Avatar
Looks good. Nice find on the parts Burb. Is it too rough for someone to save?
Advanced Design is offline   Reply With Quote
Old 05-23-2015, 09:44 AM   #13
Daveiaff
Found a good spot for the dual air compressors and tank,
Old 05-23-2015, 09:48 AM   #14
Daveiaff
ECE 2.5 drop spindles - 20x8 Salt Flats - just in, test drive out of garage 10'.
Old 05-29-2015, 04:43 PM   #15
Daveiaff
Rack mounted.
Old 06-04-2015, 08:30 PM   #16
Daveiaff
Fenders back on.
Old 06-05-2015, 05:13 PM   #17
Daveiaff
Slowly coming back together.
