#426 |
Re: "Project Orangepeel" 52 A.D
Yeah, maybe I'm over thinking it....The metal around the mirror looks like something is missing!
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#427 |
Thank's R46!! The stainless would have been nice but no way of cutting stainless that thick in the shape I was going for...(Don't have a plasma yet so all with bandsaw or cutting wheels)
#428 |
There was another idea I had been thinking of...
This involves the Visor, I will be "V" butting the windshield for a cleaner look. so in order to keep the visor it will need a mount to keep it from flying off the truck. So this short update involves the making of my new mount.. Pic #1. Is the template for the arm for the mount.. Pic #2. cutting out on band saw..
#429 |
Pic #1. rough cut of the arm, and fit,trim etc..
Pic #2. It looked sad with no holes..So I put a few in it to dress it up a bit. Pic #3. Showing the small plate that was welded to the arm and will bolt to the cab. (will drill holes for flange nuts) so arm can be removed as needed
#430 |
those two pieces compliment each other well, nice touch.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#431 |
Thank's 99..
#432 |
Great custom details, Mark!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#433 |
![]() Join Date: Jul 2012
Well done! Really like the piece.
#434 |
RockinKees and A.D. Thank's guy's!!
#435 |
Nothing to jump up and down about lately, but I was able to get a few hrs in on Sat. on my dash, doing a bit of clean up and spot weld as needed. (No pics sorry) getting it ready for final metal finish/texturing before clear...
Been fairly busy with shop projects and helping out a friend on his 49 F*&d truck...we cut the stub that was on it (drove like a pickle wagon) And installed a S-10 front stub over the past week and trying to get it ready for the show season.. Hope to get some stuff done on mine and get some more updates.. Mark...
#436 |
Customers cars, friends project, your truck...when do you sleep?
![]() Looking forward to seeing the dash done with clear...have been going back and forth on painting or leaving the 35 Coupe in bare steel ...and don't believe their is a real good way to protect the steel from corrosion if left unpainted. |
#437 | |
Your right on that one...I was on the fence about doing bodywork and paint on the dash/interior as well.
with all the really small areas that are hard to get to I figured it would be a bit easier to do in bare metal/clear.. As far as the sleep thing I get plenty haha, I should be putting in More time in the shop to finish thing's up lol.. Quote:
#438 |
Ok, boy's here is an update for you...
Pic #1. I finally had a bit of time to work on the dash. I sprayed it with encapsulator first.. Pic #2. Then with satin black... Pic #3. Then painted all the gauge pods on the inside.. Pic #4. after I did my texturing and ready for clear.... The texturing was a pain in the Butt, do to the small areas so I ended up having to make it very random... The remaining portions of the dash were done with a DA sander and 36 grit paper..
#439 |
Pic #1. After clear was sprayed...
Pic #2. The dash set back in place to see how it looks.. Pic #3. No light on for a diff. look... Pic #4. With 3 gauges set in place... Give me your thoughts...... Mark...
#440 |
Looking good Reaper, looking good. I've got to admit, I enjoy metal work but I've got no style. I can make things work but they look functional and don't have any style to them. Your stuff has style.
Rob
My '47 C.O.E build Last edited by 47 Fasttoys; 02-02-2015 at 09:19 PM. Reason: added |
#441 |
Looks awesome! Gauge pods being painted are a nice touch...matching the gauges.
#442 |
Looking very sparky!!
#443 |
nice work and damn I like your shop
#444 |
Yep, that's it !
#445 |
Thank's Rob.. I wouldn't say you don't have style your build is all style!!
#446 |
A.D.,R46,99 and Kees thank's so much Guy's for the compliment's....
I wasn't 100% sold on the Dash outcome, I felt it didn't have enough "POP" to it (Maybe because I have been looking at this thing for sooo long!!) Was thinking silver flake on the very upper part of dash and garnish moldings,the remaining stays the same.. Whatcha Think??
#447 |
Well, I really like the dash as is....and the flake would look good too. Choosing between the two, I lean toward the dash as is. It shows the good metal work. How reflective will it be when you drive into the sun?...crap, sounding like my Grandpa now. Either way it is cool.
#448 |
Looks good dude!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#449 | |
Thank's Doug for the input!!
I was thinking the same...I will be running the visor which helps with the glare.. Quote:
#450 |
