Old 01-13-2015, 12:55 PM   #1
83swb
Proportioning valve issues.
Just redid the WHOLE brake system on my truck, with the exception of a booster.
I bought a CPP factory style combination valve to replace the factory one that was in rough shape. All the brakes are plumbed correctly and the master cylinder and booster are in working order. I'm only getting some fluid to the rear brakes and the drivers side front caliper, the passenger side caliper is bone dry. I have a little pedal with the truck not running and no pedal when the truck is running (after some bleeding obviously).
I know there's some crazy sliding valve in the combination block, but how do I get it to open up?
83swb is offline   Reply With Quote
Old 01-13-2015, 01:07 PM   #2
MikeB
MikeB's Avatar
Re: Proportioning valve issues.
I assume the new valve has 2 ports for the front brakes, as opposed to a single port with a line running down to a tee fitting? Any pictures?
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-13-2015, 01:14 PM   #3
83swb
Yes, one port for each side. Its identical to a factory valve, just machined from brass.
Old 01-13-2015, 01:45 PM   #4
775stepside
Interested in what this might be because I plan on replacing all my lines too, what did you use and where did you buy the lines?
775stepside is offline   Reply With Quote
Old 01-13-2015, 01:50 PM   #5
geezer#99
geezer#99's Avatar
You need to push the button in on the front and hold it in while you bleed.
Old 01-13-2015, 02:53 PM   #6
83swb
Actually borrowing a GM tool to do that but the tool won't work with an aftermarket valve. Looks like that what I'll be trying next.
Old 01-13-2015, 02:54 PM   #7
83swb
Used copper coated easy-bend line from a local parts store, I'll never use anything else.
Old 01-13-2015, 04:59 PM   #8
MikeB
MikeB's Avatar
Looking at this diagram of a generic combo valve, both front ports go to the same place, with initial pressure delayed by a metering valve. If you have pressure at one port, you should have pressure at both. I wonder if a Chinese worker forgot to drill a hole?
Mike
Old 01-13-2015, 06:26 PM   #9
83swb
Thanks for the diagram. I was able to get some fluid to the passenger side but I'm waiting for a second pair of feet to bleed them out.
Old 01-13-2015, 08:29 PM   #10
mpierce9
I ran into a similar issue a few weeks back. My solution was
1. Clamp down the Combo valve button.
2. Remove the MasterCylinder cap
3. open the rear bleeders (both sides)
4. monitor the MC fluid level
It took 48 hours to get good fluid out.
All this should be able to be resolved with a two person bleeding job much quicker. I was told that slow 1 pedal pump bleeding works best because the volume of air stuck in the line after making such major changes.
I was making the mistake of doing a two person bleed job allowing the person that pumped the pedal to pump it up multiple times to build pressure. This was causing my issue that filled the line with air and didn't allow fluid to the rear.
mpierce9 is offline   Reply With Quote
Old 01-13-2015, 09:05 PM   #11
mpierce9
Old 01-13-2015, 09:58 PM   #12
MikeB
MikeB's Avatar
The latter half of this video is a good demonstration of how the metering valve works. All it does is delay pressure to the front brakes. But you can see how both front ports should have the same pressure.
I still don't have a real handle on the inner workings of the prop valve, but I know that it limits maximum pressure to rear drum brakes in a disc/drum vehicle. Of course, you're stuck with the preset pressure determined by the spring.
https://www.youtube.com/watch?v=PlElcEGjfd8
Mike
Old 01-13-2015, 10:12 PM   #13
83swb
Found a possible issue tonight. Somehow (dumbass me) didn't realize that I had the lines switch from the master cylinder to the valve, had the front reservoir feeding the back and back feeding the front brakes. BUT the bigger issue was the way the valve itself was machined. The valve is machined for a 3/16" line for the rear inlet (should be 1/4) and the front half is machined for a 1/4" (should be 3/16").
So this valve is getting sent back to summit and I have a line on a factory valve to put in its place.
So beware if buying a CPP combination valve for your truck, may have been mishap in the machining process.
Old 01-14-2015, 07:55 AM   #14
MikeB
MikeB's Avatar
That's seems odd. Can you post pictures of this valve and its part number?
Mike
Old 01-15-2015, 12:13 AM   #15
nonstop
CPP had a bad batch of valves a few years ago. I added discs to a 50 Chevy truck and the valve was leaking out the back with no miles on it. Googled it and found out there were many folks with this problem. I'm not too impressed with the quality control of some of CPP's stuff. Might be better off with a JY replacement.
nonstop is offline   Reply With Quote
Old 01-15-2015, 09:58 AM   #16
83swb
I'll take a few pictures of the valve tonight, haven't been keeping track of responses.
Old 01-15-2015, 10:52 AM   #17
MikeB
MikeB's Avatar
Yeah, their stuff is hit and miss. I bought a pair of their upper control arms (not the budget models) for a 55 Chevy car, and they were great. But both of the pre-installed ball joints had cracks in the grease boots. And my buddy had the exact same problem a few months later!
I think most of their their stuff comes from China, and their customers do the QA. I will say that Aaron at CPP sent us both new sets of ball joints, but I ended up using Moogs.
Buying CPP products from Summit Racing is the only way to go, because of their customer-friendly return policies.
Mike
Old 01-15-2015, 11:04 AM   #18
hatzie
Moderator
hatzie's Avatar
There are two tools that might help
I'm using nomenclature, in quotes, from the cutaway pic in post #8...
Kent Moore J-23709 is little more than a 90 degree bent piece of stiff metal with a slot that fits under the mounting bolt. The 90 degree tang depresses and holds the "bleeder rod" to center the "pressure differential valve" piston.
There's another slick little tool that temporarily replaces the warning lamp switch and locks said piston once it's centered. This tool from Brothers Truck Parts --->http://www.brotherstrucks.com/prodin...number=PVBT087 There are many other suppliers.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-15-2015, 12:35 PM   #19
83swb
I did have a GM tool to compress the bleeder, but found my real issue before trying it.
Old 01-15-2015, 06:08 PM   #20
83swb
Should have made them bigger, oh well.
Old 01-16-2015, 03:18 PM   #21
RichardJ
>> holds the "bleeder rod" to center the "pressure differential valve" piston.<<
The pin sticking out of the metering Valve (bleeder rod), has nothing to do with the "pressure differential piston". Moving that pin in or out DOES NOT move the pressure differential piston.
I said "in or out" because on some combination valves, the pin must be held "out" when bleeding. This tool is a spring clip that holds the pin "out" for that type of combination valve.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-16-2015, 03:25 PM   #22
RichardJ
Kent Moore J-23709 is shown below being used on a combination valve that requires the metering valve pin to be held "IN" while bleeding.
Old 01-16-2015, 04:44 PM   #23
Just call me Sean
Just call me Sean's Avatar
The proportioning valve with the pin you hold is used on single reservoir master cylinder systems.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
