Old 01-13-2015, 02:49 PM   #1
GMC-YA68
GMC-YA68's Avatar
steering wheel install issues (pics)
I ordered the classic Grant #967 and was told to get the install kit 3163 for my 1972. Well things are just not making any sense here. Take a look for yourself.
Does the original horn plunger stay where it is at? Or do I take the blinker mechanism all the way out and remove the stock? Plus the hub didn't look like it would even line up with the stock plunger location...any input??
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-13-2015, 06:15 PM   #2
65standard
65standard's Avatar
Re: steering wheel install issues (pics)
Where's the canceling cam?
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 01-13-2015, 06:21 PM   #3
ho70
ho70's Avatar
I never got mine to work-th directions also want you to change the spring in the plunger
ho70 is offline   Reply With Quote
Old 01-13-2015, 06:27 PM   #4
65standard
65standard's Avatar
Leave the spring loaded plunger where it's at, then install the white canceling cam, then install the wheel adapter. Make sure the tube on the white cam goes through that hole on the adapter.
Old 01-13-2015, 09:05 PM   #5
GMC-YA68
GMC-YA68's Avatar
I found what you may be calling the cancelling cam, but it looks like the tube was hacked off (on purpose).
Once I install that, and then the hub and get the nut snug it is up against the factory plunger. Is that correct? (see pic)
Then the new plunger is too long to go back down thru the hub. (see pics). I have never had this much trouble installing a dang steering wheel and am getting impatient!
-Keegan-
Old 01-14-2015, 11:14 AM   #6
65standard
65standard's Avatar
That cancel cam is broke. Get a new one if you want the horn to work and the turn signals to cancel after turn.
Old 01-14-2015, 01:35 PM   #7
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
X2
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 01-14-2015, 06:10 PM   #8
65standard
65standard's Avatar
The new horn plunger goes through that hacked off tube you don't have. Get the canceling cam, then install the wheel adapter with the tube part going through that hole in it. Then install the horn wire into the canceling cam tube. Once you get the new part, it will all make sense, fit, and work...
Old 01-15-2015, 03:10 PM   #9
GMC-YA68
GMC-YA68's Avatar
thanks. Luckily LMC is local so I'll stop in and grab one. I'll report back. Thanks for the help.
-Keegan-
