01-13-2015, 09:45 PM | #1 |
how much paint?
I want to paint the inside of my truck with actual auto paint from a gun ,but don't know how much to get? Also what else is required I am new to this paint thing, I am a wrench so please forgive me. Any help would be appreciated.
Between saying and doing many a pair of shoes are worn out |
01-13-2015, 09:48 PM | #2 |
Re: how much paint?
I had a quart for the inside and I only got the top, dash, and back wall sprayed with 2 coats and the floor and firewall 1 coat and ran out. Made me so mad! I hate running out of paint. Still have to paint the inside of the doors too. So at least 2 quarts maybe 3.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
01-14-2015, 04:53 PM | #3 |
Re: how much paint?
It all depends on gun type and paint. 1 quart of ppg single stage with reducer and activator would be plenty out of a good gun. If using a cheaper gravity fed gun with a stock cup you end up wasting some paint due to angle of application on the roof. I use pps (positive pressure system) with a good gun so I can spray at any angle. I would get two qts to be safe and reducers and activators. What brand of paint were you lookin at? I only have a Qt of house of kolor candy red to do the inside of my 65 so will c.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
01-14-2015, 05:05 PM | #4 |
Re: how much paint?
Check with the paint mixer first to see if it is a color that covers well. Some reds and Yellows seem to require twice as much paint to cover. Also depends on how much contrast from primer to paint. Some painters tint the primer or sealer to make it cover better.
01-14-2015, 10:59 PM | #5 | |
Re: how much paint?
I can get basf paint threw my work. I have watched a lot of paint jobs be done but have not done much my self I have only primed body panels. I am tired of having good running ugly trucks. Thanks for all y'alls help.
01-15-2015, 09:27 AM | #6 |
Re: how much paint?
If I rememeber correctly BASF is a 4-1 mix on bascoat clearcoat so two qts should be plenty depending on color. if it's a lighter color then get 3. Single stage might be the way to go for you just don't know the mix ratio off hand for it but ss paints tend to cover better with cheaper guns. Lay your first coat kinda light maybe a 30% overlap in coverage then on the second go with a 75% overlap and go slower to achieve that nice wet look.
01-15-2015, 09:56 AM | #7 |
Re: how much paint?
I used ss urethane and the mix is 4:1:.5. Its Hot Rod Flatz.
01-15-2015, 11:26 AM | #8 |
Re: how much paint?
I will also vote for 2 qts. It's nice to have a little left over (for touch up or whatever) as opposed to running out.
"Life is too short to drive a boring vehicle". Later, Wayne |
