Old 01-14-2015, 10:23 PM   #1
72ChevyMan1
4/6 or 5/7 drop
Does anyone have any photos of these 2 drops? ! Can't figure out which way to go. Can't afford to bag if right now so won't do that till further down the road. Thanks in advance guys. Appreciate all the info
72ChevyMan1 is offline   Reply With Quote
Old 01-14-2015, 10:28 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: 4/6 or 5/7 drop
5/7
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-14-2015, 10:29 PM   #3
slow-1
slow-1's Avatar
Re: 4/6 or 5/7 drop
http://67-72chevytrucks.com/vboard/s...d.php?t=471442
Click on the link above and spend the next 2 days seeing awesome lowered rides.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 01-14-2015, 10:31 PM   #4
72ChevyMan1
Re: 4/6 or 5/7 drop
Leddzepp did you get a kit or just springs? Any modification for that stance? I'm wanting something I can fit at least 18 or 20s
Thanks slow-1
Old 01-14-2015, 10:32 PM   #5
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: 4/6 or 5/7 drop
Here is my '68 with a 4/6 (Wheels are 20"/22")
And my '71 with a 5.5"/7" (Wheels are 20"/20")
The wheels/tires you choose will play into your drop choice; size as well as back spacing are critical when you go this low.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-14-2015, 10:33 PM   #6
72ChevyMan1
Re: 4/6 or 5/7 drop
I'm not wanting to modify the frame at this point until I can afford the bag setup n what not.
Old 01-14-2015, 10:33 PM   #7
72ChevyMan1
Re: 4/6 or 5/7 drop
Attachment 1349822
Attachment 1349823
Any frame mod on the 5/7 drop?
Old 01-14-2015, 10:37 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Re: 4/6 or 5/7 drop
Thanks slow-1
2.5" dropped spindles up front with stock springs and 1 full coil cut from each. 5" springs out back with 2" blocks. Frame is c-notched, have shock relocaters and an adjustable trac bar. Didn't use a kit, pieced together through sales and craigslist.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-14-2015, 10:53 PM   #9
scotts72heavyhalf
scotts72heavyhalf's Avatar
Re: 4/6 or 5/7 drop
5/7 drop with no frame mods.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 01-14-2015, 11:09 PM   #10
C10_ustacould
Re: 4/6 or 5/7 drop
Edited my earlier post...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-15-2015, 11:58 AM   #11
Ekliptix
Ekliptix's Avatar
Re: 4/6 or 5/7 drop
This ^
Ekliptix is offline   Reply With Quote
Old 01-15-2015, 01:21 PM   #12
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: 4/6 or 5/7 drop
Thought I'd throw this in:
338 20's with an ECE 4.5 (2.5" spindles, 2"coil) /6 static drop. All ECE under there.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 01-15-2015, 07:23 PM   #13
Mike C
Mike C's Avatar
Re: 4/6 or 5/7 drop
Mine is the beater version of that truck! All ECE in the front. DJM flip in the rear. 2 1/2" spindles, 2" springs lowered it almost 4 3/4. Flip put it down 7 in the rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-21-2015, 11:02 AM   #14
ShawnAlexander
Re: 4/6 or 5/7 drop
I did the 3" coils up front and steering rods are rubbing the idler and pitman arm mounts. Do I need to do the drop spindles to cure this problem. They are rubbing without the motor even in the truck so Im concerned that when I get it in with the extra weight it will just get worse. Any info appreciated.
ShawnAlexander is offline   Reply With Quote
Old 01-21-2015, 11:39 AM   #15
7D-TWO
7D-TWO's Avatar
Re: 4/6 or 5/7 drop
Mine had 2.5" spindles but switched to cpp modular 2".....which i didn't notice a difference at all in the stance. So I guess it's a 4/7 drop now. 2" spindles 2" springs front and 5" springs 2" blocks on back and c-notch.
7D-TWO is offline   Reply With Quote
Old 01-21-2015, 01:55 PM   #16
DaHos
DaHos's Avatar
Re: 4/6 or 5/7 drop
For those that are running a 6" rear spring, how much clearance do you have between the frame and axle.....Trying to do some mock up but with out a body/engine etc on it. Im trying to get an idea of (loaded) ride height.....
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-21-2015, 03:53 PM   #17
67 cst swb
67 cst swb's Avatar
Re: 4/6 or 5/7 drop
This will be different for a few reasons. A shortbox stepside weighs less than a short wide box and a longbox will weigh more than each of those.
So, the same 6" rear spring will "typically" not need a c-notch in a short box stepside, while a longbox will "typically" most likely need to be c-notched due to the extra weight.
As far as the short wide box with a 6" rear spring. Its about 50/50 whether it will bottom out or not.
Hope this helps.
Oh, and as a mock up height?... I take the rear spring completely out, letting the rearend rest on the bump stop (provided its still in) that is close to an approximate 6" lower spring ride height, again totally depends on the weight and other factors for end result actual ride height..
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 01-21-2015, 04:09 PM   #18
magwakeenercew2jh
Re: 4/6 or 5/7 drop
3/4" before the untrimmed bump stops. No C notch. 20" wheels w 275/45's.
Shock relocator kit.
I give it mild hauling tasks. When the work is heavier, I'm close to home. But, so far (a couple of years) , no bumping on the stops.
Early pic:
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 01-21-2015, 04:36 PM   #19
DaHos
DaHos's Avatar
Re: 4/6 or 5/7 drop
Hope this helps.
Oh, and as a mock up height?... I take the rear spring completely out, letting the rearend rest on the bump stop (provided its still in) that it close to an approximate 6" lower spring ride height, again totally depends on the weight and other factors for end result actual ride height..
I completely understand....Looking for a "range"...lol
It is a SWB Fleet.
Bumps are gone..
With just the weight of frame it sat at 4.5"......Mockup was done loaded to a ride height of 3". So looks like I was guessing in the correct range......
THX !!
1967 C10 SWB
Old 01-21-2015, 05:15 PM   #20
leddzepp
Moderator
leddzepp's Avatar
Re: 4/6 or 5/7 drop
At 5" my truck bottomed out routinely and needed a notch. You will get answers all over the place.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-21-2015, 06:17 PM   #21
ShawnAlexander
Re: 4/6 or 5/7 drop
Truck height looks great. Did you have to trim both the front and rear bump stops?
Old 01-23-2015, 06:16 PM   #22
Skerbs1
Skerbs1's Avatar
Re: 4/6 or 5/7 drop
2.5 inch drop spindles/ 3 inch coil springs in back
Skerbs1 is offline   Reply With Quote
Old 01-23-2015, 10:49 PM   #23
70cst
70cst's Avatar
Re: 4/6 or 5/7 drop
4-6 Drop
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-24-2015, 03:06 AM   #24
sprint_9
sprint_9's Avatar
Re: 4/6 or 5/7 drop
This is very true information, and to me will make or break the truck
sprint_9 is offline   Reply With Quote
Old 01-24-2015, 03:18 AM   #25
leddzepp
Moderator
leddzepp's Avatar
Re: 4/6 or 5/7 drop
Another set of shoes
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
