01-14-2015, 11:38 PM | #1 |
Welding floor pan and rocker
I'm getting ready to put in a floor pan patch and new rocker on the truck. I'm still in the measuring/planning stage at this point, and I noticed how close the fuel tank is to the area that I'm going to be working in.
With the tank right under the seat, it makes me nervous to be welding (and also grinding/cutting) right above it. Since this is a a very common repair, I imagine I'm not the first to have this concern. What have you all done to mitigate the risk? I suppose the tank could be removed entirely, but short of that, what's the safest way to work in that area?
'84 K20 350/465/208 |
01-14-2015, 11:59 PM | #2 |
Re: Welding floor pan and rocker
Probably just a safe bet to remove the tank and plug the lines off until you are done. It would be a shame for it to go up in flames and then say "Man, I should have removed that tank.
I went to school with a guy who had taken his very nice 427 short bed step side to a local garage to have some work done to it. The tank was setting in the bed of the truck with fuel in it. The owner of the shop grabbed that tank and pulled it across that bed towards him and it must have been static but it ignited and burned the truck and shop down. No Joke. Just be careful.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
01-15-2015, 01:50 AM | #3 |
yup remove the tank, I would also keep it outside and not in the building you will be welding in, it's the fumes that will get you even if the tank is empty, it takes months to air one completely out
01-15-2015, 01:53 AM | #4 |
So you think take both tanks out then? With fumes being the issue, I'm not sure I trust the other thank then either...
01-15-2015, 01:57 AM | #5 | |
though I have seen muffler shops weld on trucks with 25 gallons of fuel in them, I would not take the chance myself |
01-15-2015, 01:59 AM | #6 |
Fire extinguisher I've got for sure - no question there. All the welding I've done had been off of vehicles in the past (and mostly outside), so it's the hazard of the truck itself that's new for me on this one.
01-15-2015, 02:08 AM | #7 |
What you don't want is an EMPTY tank. You cannot get an explosive mixture with gasoline in a tank with fuel in it. The mixture is way too rich to ignite. Empty the tank, however, and a little remaining fuel can turn it into a bomb.
Rich Weyand 1978 K10 RCSB DD. |
01-15-2015, 02:09 AM | #8 | |
https://www.youtube.com/watch?v=JP_NsXmyn5M |
