01-16-2015, 10:38 PM | #1 |
another am radio question HELP!
ok. been searching but i dont seem to have the wiring spades listed as others do...or im confused...or both.
If i hook up power to the 12v spade and ground the radio...it remains dead when grounded. knob on/off makes no change if i hook up power to the unmarked middle spade, it lights up when grounded. knob on/off makes no change everyone says hook power up to the one that says 12v. but it only looks to work when i do it on the middle one...so im confused. haven't even got to the sound part yet
Every new beginning comes from some other beginnings end |
01-16-2015, 11:28 PM | #2 |
Re: another am radio question HELP!
Here's a picture of a radio wiring harness. Maybe it'll help. Looks like the 12V/power wire is at the end. Other 2 are speaker.
01-17-2015, 10:57 AM | #3 |
antennae must be hooked up or the radio will be quiet. I agree with FirstOwner69 on the wiring. Also if the radio is powered up with out the speaker hooked up(and the correct resistant speaker) you can quickly burn up the ceramic fuse in the output circuit. Bruce
01-17-2015, 12:37 PM | #4 |
what ohm is the oe speaker?
1967custom |
01-17-2015, 02:21 PM | #5 |
8 ohm. Below is a link to the place that reproduces the correct speaker. The magnet on these is round and they supply a wood block that replicates the original magnet. That is required for mounting when the original bracket is used. I have one of these and it works great. This link also contains pertinent information.
http://www.turnswitch.com/speakers.htm Last edited by FirstOwner69; 01-17-2015 at 02:38 PM. |
01-17-2015, 02:37 PM | #6 |
great thank you
1967custom |
01-17-2015, 05:46 PM | #7 |
I will second that speaker. It is very good. Bruce
01-17-2015, 05:59 PM | #8 |
Carpe manana
x3 - US built and a good deal IMO, I used one in a K10. The owner has also refurbished OEM truck and van AM/FM radios for me.
01-17-2015, 11:43 PM | #9 |
it has two little speakers that were from the aftermarket 'replica' stereo. which i believe are 8ohm...i can't remember the company off hand now but its the common one that everyone buys as a modern replica. too lazy to go out to the garage right now to see.
i tried it with an 8ohm sony bookshelf speaker when trying all the connections. again, silence but lights up when grounded if i hook the 12v to the MIDDLE spade. if i hook it to the end one that says '12v' the radio does nothing. im thinking its dead, not sure how else to know. i thought maybe if it lights then there was a chance.
01-17-2015, 11:46 PM | #10 |
does it look like all the spades on that plug are evenly spaced. on the back of the stereo they are not. its a slightly wider gap to the one that says 12v. does it look like that on your plug too?
01-17-2015, 11:55 PM | #11 | |
EDIT: Your picture in post 1 shows only 2 wires. There should be 2 wires to the speaker as in the picture I posted in post 2. |
01-18-2015, 12:08 AM | #12 |
I zoomed in on the picture in post 2 in order to show the ends of the 2 wires that connect to the speaker. You can even see how these broke off the speaker.
01-18-2015, 12:12 AM | #13 | |
this radios light comes on regardless of whether the knob is turned on or not....again....dunno what that really means. but the light doesnt go on or off with the knob. just constant on if 12v to middle spade. its probably screwed but it looks nice and original... i guess part of me just wanted to hear some old time crackly am coming out of it. even if i will never turn it on
01-18-2015, 12:15 AM | #14 |
Here's a zoomed pic of the radio end. Looks like they are evenly spaced. I'd check, but I'm 2000 miles from the truck and my spare radios.
01-18-2015, 12:22 AM | #15 |
oh ok thats pretty clear...thanks.
01-18-2015, 12:26 AM | #16 |
Just looked of a different picture I have on file from an old eBay listing. In that shot, it does appear the hot wire is spaced farther than the 2 speaker wires are spaced.
01-18-2015, 12:35 AM | #17 |
This thread has some diagrams for radio installation. It clearly shows the power wire to the spade closest to the side of the radio.
http://67-72chevytrucks.com/vboard/s...d.php?t=518727 Last edited by FirstOwner69; 01-18-2015 at 12:45 AM. |
01-18-2015, 12:36 AM | #18 |
ok cool. thought maybe my radio was weird. well. it must be a dud
01-18-2015, 12:38 AM | #19 |
01-18-2015, 01:02 PM | #20 |
awsome...thx...i missed that when i was looking at these on my phone.
very helpful
01-18-2015, 01:08 PM | #21 |
i see by this i am also missing the spacer and nuts that go on before the chrome spacer and knobs
