Old 01-18-2015, 01:00 PM   #1
Gregski
Gregski's Avatar
At what RPM does your 350 SBC idle?
Rather than staring WWW III asking more timing advance questions, let me just ask you this:
When your V8 350 cubic inch small block chevy is warmed up properly and purring like a kitten, what is your tachometer reading? What RPM is it happy at?
Since the manual splits the idle adjustments into Automatic and Manual, please let us now which one you got an auto or a stick, thank you very much.
Gregski is offline   Reply With Quote
Old 01-18-2015, 01:10 PM   #2
Gregski
Gregski's Avatar
Re: At what RPM does your 350 SBC idle?
apologies I accidentally dropped this in the wrong forum, it was meant for the 73-87 section, but if you don't mind please provide your feedback as well
Old 01-18-2015, 01:42 PM   #3
BruthaMan
US Army Veteran
BruthaMan's Avatar
350 crate motor at 260hp, idle set at approximately 650-700 rpm.
BruthaMan is offline   Reply With Quote
Old 01-18-2015, 01:55 PM   #4
Wrenchbender Ret
Same engine as Thaman. Manual trans. 3-2 carbs. It idles real nice about 700 RPM.
Wrenchbender Ret is offline   Reply With Quote
Old 01-18-2015, 05:53 PM   #5
Racer382D
Racer382D's Avatar
Truck isn't together right now but the 350 in my camaro idles right here.
http://youtu.be/JMm3QcF9-R4
Racer382D is offline   Reply With Quote
Old 01-18-2015, 06:45 PM   #6
48richard
48richard's Avatar
350/ TH350 idles at about 550 in park, and 400 in drive with A/C on.
As an aside, a couple of years ago I was very close to not passing emissions at idle, so I slowed down the idle to 450 in neutral for my recent test. It was OK but not as smooth as normal. Solved the emissions issue, though.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 01-18-2015, 06:46 PM   #7
msgross
msgross's Avatar
sounds like it should be in the Engine Section...
700 or so seems nice
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-18-2015, 07:59 PM   #8
Husker
Husker's Avatar
700-750
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 01-18-2015, 08:42 PM   #9
71K20chevy
71K20chevy's Avatar
Mine is not consistent, I think the mech. advance in my distributor is sticky. Anyway most times it's 1000 but sometimes I can get it to drop to 750.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 01-18-2015, 11:03 PM   #10
No8Easy2
No8Easy2's Avatar
350/ TH350 idles at about 550 with AC off
"They Don't write songs about Hondas "
1972 C10 "Ole Red--blood, sweet & beers"
USMC 1989-1997 1st Anglico
No8Easy2 is offline   Reply With Quote
Old 01-18-2015, 11:14 PM   #11
yuccales
yuccales's Avatar
350/350, 650 rpms, timing @ 10, smooth 17ins of vac. Running good.
yuccales is offline   Reply With Quote
Old 01-18-2015, 11:21 PM   #12
Blue/72
Blue/72's Avatar
My 1972 with 350/350 combo idles at about 800 in park and 700 in drive, my brothers 1967 idles at 700 in park and 600 in drive and my dads 1969 350/700r4 with quite a few upgrades idles low at 600 and in part at 500 or below with a lot of lump from the cam.
My dad always says that HEI distributers are pointless...
•1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money..
•1967 c10 with tach, dropped 3/5 on deep dish rally's
•1972 Cheyenne Super. Sold
Blue/72 is offline   Reply With Quote
Old 01-20-2015, 01:27 AM   #13
Gregski
Gregski's Avatar
thank you all I think I will split the difference of what the manual says and the feedback I have received 600 ~ 900 and set mine back to 750 where it was before I replaced the points distributor with the H.E.I.
Old 01-20-2015, 11:21 AM   #14
Tinkermc
I set mine at 700
Tinkermc is offline   Reply With Quote
Old 04-17-2016, 12:38 PM   #15
Pipesmatt
1972 C-20.. stock 350/350.. in park, idles at about 650 warmed up.. 550 in gear.. just got a new Quadrajet yesterday, same idle rpms in gear but sputters at 550 at a stop... 3100-3200 cruising rpm at 65mph...
Pipesmatt is offline   Reply With Quote
Old 04-17-2016, 12:39 PM   #16
davepl
davepl's Avatar
Bone stock cam, 650 in Neutral, 550 in Drive.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-17-2016, 09:35 PM   #17
57larry
800-900
57larry is offline   Reply With Quote
Old 04-17-2016, 10:30 PM   #18
jdalexa84
my truck idlesat 650 when warm and in park 350/ 200-4r.
just finished the swap on trans and loving the 2100 rpm at 70mph
jdalexa84 is offline   Reply With Quote
Old 04-17-2016, 11:12 PM   #19
Gregski
Gregski's Avatar
cool, what trans did you have before and what did it RPM at 70 MPH?
Old 04-17-2016, 11:32 PM   #20
jdalexa84
I had a 3 speed standard trans and I was above 3000 rpm at 70
Old 04-18-2016, 01:24 AM   #21
Gregski
Gregski's Avatar
thanks for the pic - Awesome!
Old 04-18-2016, 02:44 AM   #22
67chevy_hotrod
67chevy_hotrod's Avatar
Holley 650 and a comp hyd. 268 no stall converter, just shy of 1000 in park and about 650-700 warmed up in gear.
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 06-03-2016, 09:26 PM   #23
Mike_The_Grad
Mike_The_Grad's Avatar
Cold start: around 900 in park/750 in gear, after warmed up about 800 in park/and anywhere from 650-800 in gear.( seems to fluctuate for some reason.) 350 bored over.04,stock intake,comp cams XE250, H.E.I.,fresh rebuild original q-jet.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is online now   Reply With Quote
Old 06-03-2016, 10:38 PM   #24
geezer#99
geezer#99's Avatar
Likely caused by your mechanical timing starting to kick in.
What's your initial timing and where is your vac advance hooked to?
Old 06-03-2016, 11:16 PM   #25
Mike_The_Grad
14° initial at idle, no vacuum advance currently. Found the diaphragm is ruptured.
When I pulled the dist. to adjust shaft endplay, I actuated the units control arm and about an ounce of varnished gasoline shot out of the nipple connection. The rupture formed soon thereafter.(I've rebuilt my 4MV since then,found a saturated float,and really fine beach sand clogged inside the entire pass. side idle feed passage and partially clogging same side main well pickup.) So I've capped the can off in the mean time,and plugged the timed port it was connected to. I get 20° mechanical. Determined by advanced light measuring at 3000 rpm with vac. Advance plugged, and with vac. advance connected. (Had 52° with it hooked up and initial at 12°,then disconnected had 32° total with initial at 12°)
To be honest geezer#99 I've been contemplating PM you for some advice on this, and maybe a second opinion on a theory I have that may be the root of the issue. But wasn't sure how to approach you. I spend a lot of time searching these forums for a solution to my issue,but don't really see the same scenario that others have had, and I see your name come up quite often with positive,valid info,and a logical approach.
Not trying to hijack this thread! I'd gladly take this elsewhere if only I knew how.
