Old 01-18-2015, 01:09 PM   #1
Gregski
Gregski's Avatar
At what RPM does your 350 SBC idle?
Rather than staring WWW III asking more timing advance questions, let me just ask you this:
When your V8 350 cubic inch small block chevy is warmed up properly and purring like a kitten, what is your tachometer reading? What RPM is it happy at?
Since the manual splits the idle adjustments into Automatic and Manual, please let us now which one you got an auto or a stick, thank you very much.
Gregski is offline   Reply With Quote
Old 01-18-2015, 01:16 PM   #2
Axle
Axle's Avatar
Re: At what RPM does your 350 SBC idle?
in gear, auto, 900rpm. Any lower and I get dimming lights at stop signs/lights when the alternator ends up running too slow to keep up with the load.
Axle is offline   Reply With Quote
Old 01-18-2015, 01:19 PM   #3
rich weyand
rich weyand's Avatar
Did somebody say timing advance?
350/TH350, 700 RPM in Park, 550 in Drive. The 350 has a Comp 12-300-4 cam, which is a torquey cam, and that's with 16* BTDC base timing and a stock HEI.
I don't have problems maintaining voltage at that RPM since I put in a 94-amp 12SI alternator in place of the 43-amp 10SI. 12SI and 10SI alternators are same size, same brackets, same wiring, just swap it in.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 01-18-2015, 02:56 PM   #4
Jake Wade
Jake Wade's Avatar
650 in park with 12º initial
Jake Wade is offline   Reply With Quote
Old 01-18-2015, 03:26 PM   #5
csdineley
csdineley's Avatar
700 rpm in neutral
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's
csdineley is offline   Reply With Quote
Old 01-18-2015, 03:36 PM   #6
Tom
driving is in my blood
Tom's Avatar
My 79 with the vortec 350 idled about 600rpm in drive with the 200-4R. The 78 with the old 385 I had around 900rpm. The current 388 will probably be 1000 or so.
Old 01-18-2015, 05:40 PM   #7
bnoon
Red Ryder stock 350 auto 800 in park about 650 in drive.
Green Jeans built 350 barely idles at 950 in park and 750-800 in drive with a 3200 stall.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 01-18-2015, 09:12 PM   #8
t5noel
May I ask a somewhat related question? What would a high speed idle be with the choke engaged at cold start?
t5noel is offline   Reply With Quote
Old 01-18-2015, 09:35 PM   #9
Jake Wade
Jake Wade's Avatar
1200-1500 rpm
Old 01-18-2015, 11:39 PM   #10
SkinnyG
SkinnyG's Avatar
550rpm in drive, very stable, 10inHg.
Any lower in rpm and it's pretty "iffy."
350/TH350, 231°@.050/.470/108LSA, 10.9:1, doctored Rochester, 20° base, currently ported vacuum (was manifold; testing), 2500 stall converter, MSD box.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 01-19-2015, 12:55 AM   #11
rich weyand
When it starts it will probably be near 700, but as it warms up, it will rise to 1200 or more. Then you pop the throttle and kick kit off fast idle. I think the recommended setting for fast idle is 1200 rpm on a warm engine.
Rich Weyand
1978 K10 RCSB DD.
Old 01-19-2015, 01:55 AM   #12
86c20
86c20's Avatar
as low as she will go and still charge lol. my 86 4sp is around 850-900 in winter do to no choke and summer it seems around 650ish
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-19-2015, 11:20 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
350 in the 78 with a Holley
starts ice cold,up to 15-1600
Ends up down 5-600 any lower,
it has issues
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-20-2015, 01:28 AM   #14
Gregski
Gregski's Avatar
thank you all I think I will split the difference of what the manual says and the feedback I have received 600 ~ 900 and set mine back to 750 where it was before I replaced the points distributor with the H.E.I.
Old 01-20-2015, 04:35 AM   #15
y5mgisi
Second Chance Program
y5mgisi's Avatar
Should be about right.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-21-2015, 06:18 AM   #16
Your41Plague12
Your41Plague12's Avatar
700 in Park, 550 in gear (TH400). Ran and idled great that way.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 01-21-2015, 08:27 AM   #17
MikeB
MikeB's Avatar
Good advice. I've run 78 amp 12SI alternators (rebuilt by AC/Delco) in two vehicles over the years. One has been going strong since 2002. No dimming of the lights on either of the vehicles. Excellent info here: http://www.madelectrical.com/electri...elcoremy.shtml
Of course the dimming problem could also be caused by too much voltage drop in your wiring -- poor 12 volt and/or ground connections, or wire gauge too small.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 01-21-2015, 09:39 PM   #18
Axle
Axle's Avatar
A 12si is an easier conversion than a cs133. Never realized they where that much better at idle than a 10si.
Alex.
Old 01-21-2015, 10:00 PM   #19
rich weyand
Alex.
It's not a conversion at all, really, just a drop in. The reason they are so much better at idle is that you can get them at much higher amperages due to the better cooling. If at idle the alternator is running at only 30% capacity, 30% of 94 amps is a lot more than 30% of 43 amps!
Rich Weyand
1978 K10 RCSB DD.
Old 01-22-2015, 12:00 PM   #20
MikeB
MikeB's Avatar
I see where new cars have as much as 140 amp alternators to handle the computers and all the power doo-dads that are now standard equipment.
But have any of you guys ever measured total current draw in an older vehicle with A/C, hi-beams, radio, brake lights, etc all energized? I did it a few years ago on a 55 Chevy. Using a DC clamp-on multimeter, the max I saw was around 35 amps! Of course the car had a basic radio, no electric radiator fans, no power windows or seats, and no computers. Engine was running and battery voltage was around 14.2 volts, as I recall.
But, hey, I still like the 12SI design, and the 2x safety margin of even 78 amps, at least for my non-power doo-dad applications.
Mike
Old 01-22-2015, 04:23 PM   #21
rich weyand
It's not a 2x safety margin, because alternators do not put out their full rated amperes at idle rpm. I wouldn't expect more than a third of rated output at idle from any alternator.
Rich Weyand
1978 K10 RCSB DD.
Old 01-22-2015, 04:29 PM   #22
piecesparts
Parts and more parts
piecesparts's Avatar
383 stroker engine with a 700 R4 automatic behind as well as a Comp Cam roller setup. The idle is a little lopey, so had to put in a 2300 stall converter to allow for the tranny to not drag the engine down. I run a 700 RPM idle with the tranny in drive and around 900 RPM in park or neutral. My timing is set at 32 degrees total advance and the engine works great on the street, I also have changed my alternator to a Tuff Stuff unit that carries 80 amps at idle, so no flickering lights or stereo issues.
Prior to changing the converter, I could not keep the engine idling without setting the RPMs up to the point that the carb was no longer in the idle circuit.
Frank
