Old 01-19-2015, 12:26 AM   #1
csb#356
Stock wheel alternatives for a 16.5"
Im having trouble finding tires for my 16.5s on my 1979 K30. I've heard 17s off of a newish dodge will fit. I tried bolting on a 16" off of a late 90s chevy and the center hole wasn't big enough to fit onto the hub. I was wondering what kinds of wheels you guys have used on your one tons. I appreciate any and all the suggestions. Post up some pics if you've got em. Thanks a bunch
csb#356 is offline   Reply With Quote
Old 01-19-2015, 02:54 AM   #2
argonaut
argonaut's Avatar
Re: Stock wheel alternatives for a 16.5"
I'm pretty sure stock 16x6.5" steelies from 80s pickups will fit no problem...
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 01-19-2015, 03:11 AM   #3
andrewmp6
h2 rims fit and look good.
Old 01-19-2015, 08:12 AM   #4
Any hubcap-type 8-lug 16" truck wheel will work, as long as it isn't a newer Ford (about '96-up) Metric/170mm wheel. The Ford wheels from before that change are your best bet. Those are 1" wider than the others at 7" which is only 1/2" wider than your factory 16.5s. Those wheels will have "Accuride" stamped into them
Old 01-19-2015, 09:15 AM   #5
CrewCab59
CrewCab59's Avatar
They still make about 10 different tires in 16.5 without going into a full mud tire.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 01-19-2015, 11:04 AM   #6
csb#356
Thanks for the replies guys. I was under the impression that a 16" would not fit over the calipers in the front, They're pretty darn big compared to the 3/4 ton. I've only tried to put on the one 16" chevy wheel and like i said the center hole wasn't big enough, and it looked pretty close to the brakes. I'll do some searching and see if i can find a another 16" wheel to try. Anybody used one with success with the bigger front brakes? I'd rather go away from 16.5 tires because it just seems simpler to be able to go down to the local tire store and buy tires when i need them, plus they're pretty expensive to have them order them.
Old 01-20-2015, 09:49 AM   #7
16" could come on all 3/4 tons. 16.5s became an option around 67/68. Heck, you can mount 15" wheels. You only have to grind along the casting seem a little bit for clearance
Old 01-20-2015, 03:47 PM   #8
b454rat
Nothing changed on a Dana 60 over the years, 16s were standard in the 80s and the K30 came with them. Need to find and 80s 3/4 or 1 ton for 16s. Why not buy new wheels? Or go on craigslist. I picked up a set of 16x10 8 lugs for $200.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-21-2015, 02:58 PM   #9
RedRoad
RedRoad's Avatar
None of the 8 stock 3/4 ton 16 in rims would fit over the front hub on my 72 K20 like the OP stated, no problem in the rear.
The guy at the tire shop said they would just file the stamping high spots down a bit and they would go on with no trouble. Anyone know if these are hub centric or lug centric rims?
RedRoad is offline   Reply With Quote
Old 01-21-2015, 04:22 PM   #10
csb#356
Ok thanks guys. I will start looking at 16s also. I just havent found a set yet that would fit over the hubs but good to know they will fit over the brakes. I'd rather have 16s anyway for cheaper tires. The only 16s i did try would have taken way to much "clearancing" out of the center hole of the wheel.
Old 01-21-2015, 04:24 PM   #11
csb#356
They pilot on the lug nuts so the center shouldn't matter much
Old 01-21-2015, 04:28 PM   #12
csb#356
I'll definately be buying new wheels. I just didnt't know what i should be looking at buying on craigslist. I didnt know 16s were an option on the one tons
Old 01-21-2015, 06:35 PM   #13
b454rat
16s were stock on 3/4 and 1 tons in the 80s.
You have something going on, if 16s wouldn't fit over the hub. They are the same as any other big hub 44. If they fit a 60 then should fit a 44. Sure they were GM wheels?
Old 01-21-2015, 10:41 PM   #14
csb#356
They were gm wheels but they were from the late 90s. It has been awhile since i tried it and ive forgotten what the center hole measurement was.
Redroad- any chance you know the measurement of the OD of your hubs?
Old 01-22-2015, 08:12 PM   #15
b454rat
88-up IFS normally won't fit over hubs...
Old 01-22-2015, 08:21 PM   #16
RedRoad
RedRoad's Avatar
Dont have the measurement of the hubs but they are the early 1st series "big hub" type.
All the rims I have are early to mid 90's manufacture
Old 01-23-2015, 12:01 AM   #17
16s came on 70s/80s 3/4t as well as 1t (C, K, G & P models). Mid-90s GM wheels (IFS) won't fit. Those are steel but not "Steelies". They are "Styled Steel Wheels". I tried one on a '72 K/20, no go. I just needed to mount them on a truck that was sitting so I could borrow it's wheels for another truck. All 8-lug steelies will fit on a GM, from my experience. Ford has a larger hub, so GM wheels won't fit those. You don't want IFS wheels on a solid axle truck. The IFS wheels are made with more like a FWD offset than a RWD and will be too tucked in. I've seen them on a '79 K20 around town some years ago. I believe even the small hubs have the same diameter lip the wheel fits over. Must have machined the hubs or wheels...or that lip is smaller.
Old 01-23-2015, 01:18 AM   #18
WhiteWhale
WhiteWhale's Avatar
I am running 1996 and 2000 steel rims on my K20 burb. I did have to file a small amount of the raised stamping area like mentioned above to get them to fit the front hubs, no mods needed for the rear hubs (HO52)
WhiteWhale is offline   Reply With Quote
Old 01-23-2015, 03:48 AM   #19
argonaut
argonaut's Avatar
WhiteWhale, What size tires are those BFG MTs on your 72 Burb?
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 01-23-2015, 04:12 AM   #20
WhiteWhale
WhiteWhale's Avatar
LT255/85R16
Getting harder to find now, I think they are going to discontinue them.
They measure just over 32 inches installed on the stock rims.
The burb is running its stock suspension which is sagging a bit, hopefully getting a 2.5 TC kit soon.
Old 01-23-2015, 08:44 AM   #21
jjzepplin
jjzepplin's Avatar
I have 1989 d60 up front and have run 2002 aluminum Chevy wheels that were 16" no problem. Bolted right up no filing. Got them on CL right now cuz I went back to my bullet holes that came off a Furd?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-23-2015, 09:49 AM   #22
I was wrong about the late 8-lug wheels. Looks good. I always see people here saying they tuck in too much. I guess that's just 6-lug. Those have a more obvious inset.
Old 01-23-2015, 08:33 PM   #23
I was just in south San Antonio this afternoon and I swung into a truck salvage yard. Walked all around looking for accuride rims, only found 2 of em so I passed. He wanted 25 bucks a piece
Old 01-24-2015, 02:33 PM   #24
csb#356
Thanks for the info. Thats more like what im looking for. I'm finding a lot of good sets of wheels off of newer trucks for really cheap on craigslist, I guess everybody is buying 20s or something for their 3/4 and 1 tons I haven't been finding much for older wheels though. Thanks for the info and pics guys.
Old 02-01-2015, 12:57 AM   #25
Joesjunk
Joesjunk's Avatar
I have an 87 1 ton 4x4 that's bone stock, the factory wheels are 16 X 6.5". They are the same wheels on the K/20's also.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
