Old 01-19-2015, 11:06 AM   #1
Arl37
What do you think of my drive line Angles?
I have a 69 C10 long bed with a 350 crate and 700R4 transmission. 3.07 rear end. I just finished installin 2 1/2 dropped spindles and 4 inch dropped rear springs. I think I may have a slight vibration under hard acceleration that I didn't notice before installing the dropped rear springs. I had the front end aligned and tires balanced two days ago. To eliminate drive line as the cause I determined my two piece drive line angles as set forth below.
What do you think of them? do they look acceptable? If not why not.
Sorry I couldnt figure out how to rotate immage
Arl37 is offline   Reply With Quote
Old 01-19-2015, 12:34 PM   #2
Bigdav160
Bigdav160's Avatar
Re: What do you think of my drive line Angles?
I think it looks good. How does it drive? Any vibration?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-19-2015, 12:40 PM   #3
hamjet
hamjet's Avatar
Gotta love those angles of the dangles....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-19-2015, 01:03 PM   #4
Arl37
I have s slight vibration under full throttle. Nothing at cruising. Could be something other than drive shaft alignment.
Just trying to eliminate all possibilities.
Old 01-19-2015, 01:42 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by arl37 View Post
i have a 69 c10 long bed with a 350 crate and 700r4 transmission. 3.07 rear end. I just finished installin 2 1/2 dropped spindles and 4 inch dropped rear springs. I think i may have a slight vibration under hard acceleration that i didn't notice before installing the dropped rear springs. I had the front end aligned and tires balanced two days ago. To eliminate drive line as the cause i determined my two piece drive line angles as set forth below.
What do you think of them? Do they look acceptable? If not why not.
sorry i couldnt figure out how to rotate immage
Name:  drive shaft 002.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-19-2015, 02:17 PM   #6
geezer#99
geezer#99's Avatar
Your centre bearing is where the problem is. The u-joint there has no working angle.
Here's a link to figure it out.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
And another one.
http://www.drivetrain.com/parts_cata..._problems.html
Old 01-19-2015, 03:02 PM   #7
Bigdav160
Bigdav160's Avatar
Looking at that again, Geezer right. Although the front and rear joint will cancel themselves out the acceleration and deceleration the shaft are likely transferred to the bearing and frame.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 01-19-2015, 09:05 PM   #8
Arl37
you guys are such geniuses. i had one hole in the carriage bearing bracket left and i moved it up to that hole and solved all my vibration problems. moreover i checked my angles angles he 2nd shaft was up 3,7 not down.
thanks for your help.
