Old 01-19-2015, 04:58 PM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
"brake cleaner"
i got the diff.cover off my axle,i want to clean all the sludge before i re-bolt it.will brake cleaner work fine?or should i use somthing special for that? thanks befor hand.
1966FLEETSIDE is offline   Reply With Quote
Old 01-19-2015, 05:38 PM   #2
sprinter11r
sprinter11r's Avatar
Re: "brake cleaner"
Yes
sprinter11r is offline   Reply With Quote
Old 01-19-2015, 05:45 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Re: "brake cleaner"
Brake cleaner works great and leaves no residue, but be careful. That stuff is deadly dangerous to ingest the fumes so work outside if you can and wear a respirator. That's one item where the warning labels should really be read before use.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-19-2015, 05:57 PM   #4
1966FLEETSIDE
Re: "brake cleaner"
thanks sprinter and yes thank you markebo1
Old 01-21-2015, 10:10 PM   #5
chris1044
Re: "brake cleaner"
Don't use brake cleaner to clean anything you plan to weld!
http://www.brewracingframes.com/safe...sgene-gas.html
chris1044 is offline   Reply With Quote
Old 01-22-2015, 01:24 AM   #6
Softpatch
Softpatch's Avatar
Re: "brake cleaner"
it wont kill you right away it takes a few decades
there's a reason it's called "parkinson in a can"
it seems like alot old wrenches or having issues like Liver and or bladder Cancer.!
It's not about you.
It's about the suffering of the one's that love you that is the issue If you become ill
and this coming from a guy who chewed alot of paint chip as a kid
and drank alot of gasoline via garden hose......sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 01-22-2015, 01:57 AM   #7
Captainfab
60-66 Nut
Re: "brake cleaner"
Another option would be to go to Home Depot and get a gallon of mineral spirits and a couple cheap brushes. For some cleaning uses I prefer carb cleaner over brake clean. Of course you guys in California can't get the good stuff that the rest of us can.
Old 01-22-2015, 02:08 AM   #8
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: "brake cleaner"
Don't Spray Pinion Seal It will eat the Gasket Rubber
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 01-22-2015, 09:23 AM   #9
cg285
Re: "brake cleaner"
if you are working for someone else and they are paying for the brake clean go ahead and use that. lots of it. if you are paying for it - use mineral spirits
cg285 is offline   Reply With Quote
