#26 |
Re: Tejano 52
engine and transmission are ready to go in hopefully this weekend I'll have time to put it in
#27 |
Re: Tejano 52
I really don't know if this engine and transmission is a good combination but I guess I'll find out it is a 283 Chevy with a 400 turbo transmission
#28 |
Re: Tejano 52
#29 |
Re: Tejano 52
Replaced the flywheel to fit the turbo 400
#30 |
Re: Tejano 52
New one
#31 |
Re: Tejano 52
Getting ready to go in, got the right flywheel and I picked up some other parts for the engine last weekend at the swap meet
#32 |
![]() Join Date: Jul 2012
Re: Tejano 52
They look really good!
#33 |
Re: Tejano 52
gotNthe transmission hooked up to the engine, had a small gap between the torque converter and the flywheel, fix that with a couple washers. Not sure if this is the way it's supposed to be but it seems like it's going to work
#34 |
![]() ![]() Join Date: Nov 2008
Re: Tejano 52
Ok, I've gotta ask. What's the deal with the metallic blue tranny? Not that it matters, I suppose but it'd drive me crazy!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#35 |
Re: Tejano 52
the transmission was going on my 64 but ended up putting a Powerglide back in it so I had this transmission in the garage and that is why it's painted
#36 |
Re: Tejano 52
You don't need the washers, just push the converter into the flywheel.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#37 |
Re: Tejano 52
should I remove that it's about an inch? I'm really not sure if I was supposed to do it or not but it seemed like there was a big space between the torque converter and the Flywheel
#38 |
Re: Tejano 52
You don't need no inch, more like a 1/8 or a little more won't hurt. Don't space it back to far, the converter needs to go into the crank enough to center it.
#39 |
Re: Tejano 52
#40 |
Re: Tejano 52
remove the washers and bolted up the transmission
#41 |
Re: Tejano 52
also did the first mock up with the transmission attached to the engine it looks like we have clearance on the firewall and on the side of the engine
#42 |
Re: Tejano 52
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1436786&stc=1&d=1439865647
#43 |
Re: Tejano 52
I need some help I want to add power steering to my truck but I don't want to spend 500 to 700 I'm purchasing a power steering kit I would like to see if anyone has an idea of what gearbox to use or if anybody has done this on a low budget any suggestions and any help would be greatly appreciated.
#44 |
Re: Tejano 52
#45 |
Re: Tejano 52
Blanco,
Nice work on the truck so far. Love the Impala also! Sorry that I have no suggestions on your power steering question. I went with the S10 frame conversion, so a whole different set of problems. Keep up the good work! |
#46 |
Re: Tejano 52
Thanks I'm trying to do it all myself so it's not perfect, thanks for the props.
#47 |
Re: Tejano 52
#48 |
Re: Tejano 52
I'm going with the power steering setup from classic performance parts,I already had the power steering pump,and I'm going to get the gearbox from an 87 2 wheel drive Chevy truck maybe this weekend.
#49 |
Re: Tejano 52
#50 |
Re: Tejano 52
I'm hoping that this will work for my setup if anybody has used this before please let me know how it worksany help with this will be greatly appreciated
