Old 01-22-2015, 05:29 PM   #1
Big hec
Airride Install Help (pic request)
Hello all, I'm installing my first air ride kit on my 70 c10 fleetside shortbed. Got my kit from EZ airride. I was wondering if you guys could maybe post some pics of where you mounted compressors and tanks. My kit came with a 7 gallon tank. Its says it's supposed to fit between the frame rails, but it looks a bit to big. Any help would be appreciated.
Big hec is offline   Reply With Quote
Old 01-23-2015, 07:03 PM   #2
SCOTI
SCOTI's Avatar
Re: Airride Install Help (pic request)
2 comps & 2 3gal tanks.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-24-2015, 11:40 AM   #3
Big hec
That's what I eas thinkig. If I can get my 7 gallon to fit like that
Old 01-29-2015, 05:33 PM   #4
naynay
SCOTI can you post a pic of your shock mounts?
naynay is offline   Reply With Quote
Old 01-29-2015, 06:30 PM   #5
SCOTI
SCOTI's Avatar
I can take some better shots after work & post them tonight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2015, 07:25 PM   #6
502ms
502ms's Avatar
Don't be scared to fabricate a tank mount that centrally locates the tank in the middle of the frame and gives equi-distant line from tank to bag. Probably a good idea. My tank is in the middle of mine, but I am probably a bit more extreme than you are going.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 01-30-2015, 11:59 AM   #7
SCOTI
SCOTI's Avatar
Lower mounts are the original mounts cut off the rear end, the excess trimmed away, & then welded to the lower 4-bar mount. The upper mount is a standard C10/20/30 upper shock stud mounted to the upper bridge beam. I did have to machine the shaft to a smaller diameter to fit inside the sleeve on the Bilsteins since the sleeves are almost impossible to press out.
This arrangement allowed the slight side shift that resulted from using a Panhard bar.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
