01-24-2015, 12:00 PM | #1 |
Interchangeable parts from C50?
What parts if any will work on our trucks?
Thanks Nathan
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
01-24-2015, 01:13 PM | #2 |
Re: Interchangeable parts from C50?
To my recollection...everything in the cab...including the doors.
The dash bezel won't fit without modification but most gauges are re-usable and common. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
01-24-2015, 03:46 PM | #3 |
I actually found a perfect steering wheel in one.
01-24-2015, 04:14 PM | #4 |
Going to look at one now buying for the doors and a few other stuff I' am going to part out the rest. Not sure how I'm going to go about fixing the corners of the doors though.
Thanks Nathan
01-24-2015, 04:58 PM | #5 |
I have swapped numerous tach dashes from big gas trucks into c10s. Diesel tachs are different though. Not sure about the comment above.
01-24-2015, 06:52 PM | #6 |
does anybody know if the cab itself is the same if not what the differences are? Can it be modified to work?
01-24-2015, 07:51 PM | #7 |
Entire firewall/cowl area down to the rockers is different, there is no lower "A" pillar , the front floor section and kick panels are also different. .....
The column mount and pedal box is different and some of the heater box is slightly different.
1967 C10 SWB Owner - Rustbelt Restorations Last edited by DaHos; 01-24-2015 at 07:58 PM. |
01-24-2015, 08:01 PM | #8 |
K thanks for the information
Nathan
01-24-2015, 08:47 PM | #9 |
are the steering columns the same?
01-25-2015, 01:22 AM | #10 |
The Older Generation
Friend of mine and I put a complete floor out of a C-50 in his 4x4. Just had to make a couple of modifications to the front corners and the hump area where it meets the toe board. Here is the thread on it: http://67-72chevytrucks.com/vboard/s...d.php?t=490272 They are usually in good shape. LockDoc
01-25-2015, 01:28 AM | #11 |
LockDoc do you know of any threads that show how to fab corners for the doors from a C50. Thanks for the information
Nathan
01-25-2015, 12:12 PM | #12 | |
Don't know of anything on the board. I have a set I am going to do but it won't be for a while. I plan on doing an inner and outer piece for strength and peeling the outer skin up an inch or so so that the new outer skin can be crimped around the original inner panel. That should give it plenty of strength. LockDoc
