Old 01-24-2015, 11:01 PM   #26
stockiroc86
stockiroc86's Avatar
Re: 86 c30 flatbed cummins 2wd
Motor clearance
1930 Ford Model A coupe. Original. Black with apple green wheels.
1959 Chevy Apache 3100 stepside. Built 235 6, split header, true duals, s10 5 speed, 15x10 bullet hole wheels.
1986 Chevy C30 3+3 Camper Special. 12v p pump cummins, nv4500 5 speed. http://67-72chevytrucks.com/vboard/s...d.php?t=655695
stockiroc86 is offline   Reply With Quote
Old 01-24-2015, 11:05 PM   #27
stockiroc86
Transmission fitment
Old 01-24-2015, 11:12 PM   #28
stockiroc86
Old 01-24-2015, 11:38 PM   #29
stockiroc86
Originally Posted by slotard View Post
It's too bad you have to do a body lift on it. Not a big fan of spiked lug nuts either, the rest of it I mostly like. What're your bed plans?
I like using imgur.com to host images.
I didn't have to use the body lift but their was alot less cutting on the body that way and I like my trucks to sit up high anyway. the spikes are just a thing because i come from a family of truck drivers. The bed is a 9ft flat bed with a dump kit and quick removal tool boxes and genorator and air compressor. That way i can haul dirt or gravel if need be.
Old 01-31-2015, 07:24 PM   #30
stockiroc86
Today the interior came out and the doors off. Also got the visor off and removed the windshield
Old 01-31-2015, 07:29 PM   #31
stockiroc86
The floor pans are solid but the door jams and 1 spot around the windshield are pretty rough.
Old 01-31-2015, 07:39 PM   #32
stockiroc86
Then we moved on to removing the rest of the dash and components. This made better access to the wiring harness and alot more room for fitment of the dodge pedal assembly. Had to trim a little off the end of the pedal bracket to slide up behind the steering column support. I will also have to rework the firewall for a little for all the the holes to line up and make a brace to attach the pedal bracket to the column support.
Old 02-01-2015, 09:56 PM   #33
stockiroc86
Well today we got the dodge brake booster and master cylinder mounted. Ran in to some rust in the fire wall and cowl. Made some patch panels for the fire wall and we will address the cowl panel soon. Fit nice and snug like its meant to be there.
Old 02-01-2015, 10:01 PM   #34
stockiroc86
The firewall wasn't to bad and once again the break lines screwed right in just like the power steering lines did.
Old 02-01-2015, 10:10 PM   #35
stockiroc86
Got the pedals hooked up although I will need a new clutch master cylinder bc the retainer is broke so they had it rigged in place.
Old 02-09-2015, 12:35 AM   #36
stockiroc86
Well didnt get anything done yesterday. Had too much on my mind to focus. Today we worked on a few detail pieces on the motor and getting some stuff put on. Anodized the fuel lines purple with blue anodized nuts. Painted the valve covers with black wrinkle paint. Got everything bolted back on the fuel pump. Think I about red anodizing the turbo compressor, air to air tubes, and intercooler.
Old 02-09-2015, 12:38 AM   #37
stockiroc86
Does anybody have any ideas on doing away with the big bulky ac box on the firewall without losing the air condition? I looked in to vintage air but really dont want to spend that kind of money when all of my stuff is good and their compressor and condensor wont work as good as the dodge stuff.
Old 03-30-2015, 01:08 AM   #38
Got Smoke?
Got Smoke?'s Avatar
subscribing
97 Dodge 2500 12V NV4500... way to much to list.
79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue....
NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one....
Got Smoke? is offline   Reply With Quote
c30 crew cummins swap
