Old 01-29-2004, 02:03 PM   #1
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Hazard flasher switch
Mine has broken off.
Do I order a new switch knob (LMC $4), or do I have to get a complete switch?! Truck is a '70 w/o tilt (if it makes a difference.
Thanks all
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 01-29-2004, 03:03 PM   #2
JimKshortstep4x4
Talking
I have always just replaced the whole switch. I have not tried replacing just the red button and I did not know they were available.
Jim
Old 01-29-2004, 05:36 PM   #3
SWEET7T
SWEET7T's Avatar
Ok, where in the world are you getting a switch from? I can't find one anywhere (catalogs/parts store).
SWEET7T
Old 01-29-2004, 10:31 PM   #4
SWEET7T
SWEET7T's Avatar
ttt anyone?!
SWEET7T
Old 01-29-2004, 10:40 PM   #5
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
some of these older switches you cannot replace just the 4 way switch you have to replace the hole thing. I got mine from autozone and they had to order it. I'd order it from LMC cause if you go to the store and buy it the newer plugs don't match the old horseshoe type. You'll need an adapter and the only place i found one is lmc and they don't sell the adapter seperately. so you might as well buy the switch from them in the first place
WRMZ71 is offline   Reply With Quote
Old 01-29-2004, 10:51 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
I bought one from LMC for $30.....works great
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-29-2004, 11:23 PM   #7
jorgensensc
jorgensensc's Avatar
sorry to hijack the thread, but what is the correct shape of the hazard pull thing? I have a '72 non tilt and mine is a simple red piece that you push in (on) and pull out (off). I have seen them with round button types. Which is the right one??
thanks
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-29-2004, 11:26 PM   #8
JimKshortstep4x4
Talking
When I said "whole switch" I meant the whole turn signal switch.
I got the last one that I needed from Tim Christian but I am sure others have them.
Jim
Old 01-30-2004, 12:58 AM   #9
67sss
67sss's Avatar
turn signal switch
like this.......$15 and I'll send it to ya.
67sss has attached this image:
67sss is offline   Reply With Quote
Old 01-30-2004, 01:01 AM   #10
67sss
67sss's Avatar
oops here's the pic
Old 01-30-2004, 01:17 AM   #11
lukecp
lukecp's Avatar
thanks
The little red pull thing is correct. The aftermarket switches have a round button that you use to turn off the switch and are black
Old 01-30-2004, 01:22 AM   #12
jorgensensc
Thanks Yellow72custom. Mine looks exactly like the one in the pic above.
Old 01-30-2004, 01:31 AM   #13
dinnut
dinnut's Avatar
a little off topic. but where can you get that half circle thing on the end where the little wire clips go through? im converting from non tilt to tilt. can i use the old one? do i need a new one?
im putting in a new turn signal switch.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-30-2004, 07:48 PM   #14
roden001
Speaking of these red Hazard buttons, does anyone know how to get these turn signal switches (the whole unit) off without breaking the hazard button? I don't want to break mine, but I can't get any further into my steering wheel without removing it.
roden001 is offline   Reply With Quote
Old 01-31-2004, 12:32 AM   #15
roden001
bump
