Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-25-2015, 04:56 PM   #1
hotrodharley
installing a deck wiring
install a deck in my 84 Chevy truck that has a 3"led screen in it with back up camera;;ion deck wiring it says to run the white wire to parking brake switch;;at this time the parking brake assy has been removed from truck;;haven't put one back in yet;;so do I just ground the white wire from deck or do I run it to a keyed + feed or do I just leave it not hooked up until I install park brake assy? I'm assuming the white wire is to keep driver from watching dvd while driving so if park brake is on is only time dvd will work;;guess what I'm asking is if you have park brake set then is there 12 volts leaving switch or is it a ground leaving the switch when set?
hotrodharley is offline   Reply With Quote
Old 01-27-2015, 02:38 PM   #2
michael bustamante
michael bustamante's Avatar
Re: installing a deck wiring
thats a safety feature to make sure you cant watch a movie without the parking brake on. i had this with my excelon deck. ground it seperatly from the deck, no need to hook it up to the park brake switch
1967custom
michael bustamante is offline   Reply With Quote
Old 01-27-2015, 05:28 PM   #3
hotrodharley
Originally Posted by michael bustamante View Post
thats a safety feature to make sure you cant watch a movie without the parking brake on. I had this with my excelon deck. Ground it seperatly from the deck, no need to hook it up to the park brake switch
thanks
