01-25-2015, 07:04 PM | #1 |
trans fluid check 350 with turbo hydromatic
Do I check the trans fluid when the engine is cold or hot? 350 with turbohydramatic automatic trans.
thanks |
01-25-2015, 08:01 PM | #2 |
Re: trans fluid check 350 with turbo hydromatic
Hot, idling in neutral. Check your owner's handbook for more information.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-25-2015, 08:18 PM | #3 |
01-25-2015, 08:19 PM | #4 | |
But yes, hot and idling in neutral (or park). And run it through the gear positions (P-R-N-D) if it's been sitting without being driven for a while. DON'T OVERFILL! That's a bad thing to do. And realize that while the approximate fluid volume between lines on an oil dipstick is 1 quart, for the transmission it's 1 pint. |
