Old 01-26-2015, 10:36 PM   #1
Shasta123
Is this fire wall color factory
Is this factory paint on this fire wall. The truck is dark green. And the fire wall is a tan color this is 2 owner truck with only 42000 actual miles and suppose to be all original paint. 1964 model just want to make sure the color on fire wall is all original. Thanks for any help, I attached a picture I hope it worked.
Shasta123 is offline   Reply With Quote
Old 01-26-2015, 11:30 PM   #2
VictoriaHardware
VictoriaHardware's Avatar
Re: Is this fire wall color factory
Every one that I have seen is either the exterior color or the interior color (Fawn). That does not look like Fawn and does not look like the body color either, or is it just the camera? The firewall does appear to have been painted at the factory though. Is there any evidence that it could have been re-painted green? What is the paint code on the left kick panel plate? Dark Green should be 505.
VictoriaHardware is offline   Reply With Quote
Old 01-27-2015, 12:03 AM   #3
Shasta123
No evidence of re paint and code is 505 I have seen a couple of pictures of this fire wall color after looking around in thus forum hopefully someone can confirm this was factory built in the Atlanta plant
Old 01-27-2015, 12:06 AM   #4
LT1 Burb
LT1 Burb's Avatar
It's been painted, look at the rubber that the fan switch wire comes through, and the insulation pad bushing, they have been painted.
LT1 Burb is offline   Reply With Quote
Old 01-27-2015, 12:31 AM   #5
oem4me
Agreed, it does not look right. Valve cover isn't the right blue either.
Old 01-27-2015, 01:59 AM   #6
Captainfab
60-66 Nut
I agree that it's been repainted....bolt heads painted too.
In addition to the wrong blue on the valve cover, an HEI distributor has been added.
If you look at the firewall under the inner fenders, you will find the original firewall color.
Old 01-27-2015, 02:12 AM   #7
Kenfuzed
Kenfuzed's Avatar
Already covered but +1 this is definitely repainted.
- Bolt heads painted
- Heater wire grommet painted over
When I enlarge the photo it just looks like the PO repainted the firewall when they redid the engine... might have even changed the engine given the off-color cover and HEI upgrade.
Also unless the truck has been in your family this whole time it may be a long shot that those are original miles.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
