Old 01-27-2015, 09:55 PM   #1
Chucks72Longbed
Chucks72Longbed's Avatar
72 heater fan speed
Hello, anyone have any insight as to why my heater fan doesn't run in high speed? I just replaced a bad fan switch and now it runs in low and medium but not high. It's a 72 C20, 402 big block, TH400 with factory AC. Thanks
Chucks72Longbed is offline   Reply With Quote
Old 01-27-2015, 11:16 PM   #2
BruthaMan
US Army Veteran
BruthaMan's Avatar
Re: 72 heater fan speed
There is a high speed blower motor relay that sits on top of the air box connected to the firewall, in the cab
Follow the orange wire in the photo. That's where the relay is. When this relay goes bad, high speed on the fan will not work. Solution: replace the relay.
BruthaMan is offline   Reply With Quote
Old 01-27-2015, 11:21 PM   #3
Wizo
Wizo's Avatar
Check the Heater resistor. Its screwed into the inner air box up under the glove box. look like a group of 3 little springs. Couldn't hurt to check them with a volt/ohm meter. LMC carries them. Hope this helps.
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 01-27-2015, 11:23 PM   #4
Chucks72Longbed
This is awesome. Thanks a lot guys.
Old 01-27-2015, 11:28 PM   #5
Wizo
Wizo's Avatar
Word.
Old 01-27-2015, 11:32 PM   #6
Ugly 61
Smile Re: 72 heater fan speed
I had the same problem with the factory air on my 72 GMC. I put in a new blower motor, blower relay and fan switch still no high fan speed. I found that the orange wire to the blower relay had come off at the fuse box. I plugged this wire in to a terminal that is hot only when the ingition switch is in the run postion and then the blower fan works like it is suppose to. What the blower relay does is on high it bypasses the resistor and sends voltage directly to the blower fan motor.
Ugly 61 is offline   Reply With Quote
Old 01-27-2015, 11:54 PM   #7
Chucks72Longbed
More great info! So glad I found you guys! I just bought this sweet truck on 12-26-14 and love it. Always wanted one. One of my favorite chevy truck body styles. I'm am amazed how many parts are available. I'll post some pics soon.
Old 03-08-2015, 06:52 PM   #8
jimbosprint
jimbosprint's Avatar
I just fixed the high fan speed that wasn't working on my truck thanks to a quick search that turned up this thread. A new relay solved the problem.
Once again, thanks for the help 67-72chevytrucks.com!
jimbosprint is offline   Reply With Quote
Old 03-08-2015, 08:50 PM   #9
Chucks72Longbed
Yeah. It's so nice to have this group to bounce questions off of. Like sitting around in the shop shooting the breeze with all your buddies about trucks.
72 Chevy C20 LWB-Just what I always wanted.
Now, just need more time and money!
Old 03-08-2015, 09:57 PM   #10
Accelo
Accelo's Avatar
The circuit is somewhat confusing. It makes a lot more sense if you know the fan is fed with two different circuits. On has the lower voltages provided but using the resistance in the ducting. The other is a full 12 volts.
Rick in Washington State
Accelo is offline   Reply With Quote
Old 08-30-2021, 10:57 AM   #11
'72 C10 Super
'72 C10 Super's Avatar
Re: 72 heater/AC fan speed
I have a '72 with A/C and the blower switch has only off, low and high
notches in the switch as you move it....? Does a non-A/C fan switch
have only low and medium, while the A/C has low, medium and high?
'72 C10 Super is offline   Reply With Quote
Old 08-30-2021, 05:17 PM   #12
BigBird05
Not sure how to answer your question, but there are 2 different fan switches, one for A/C and one for non A/C. I just bought an A/C switch from Randy. There has been a for sale post on here for a non A/C switch also.
BigBird05 is offline   Reply With Quote
Old 08-30-2021, 05:32 PM   #13
'72 C10 Super
My fan switch only has 3 places, off, low, medium. At Medium it is bottomed out
in the slot where the switch is positioned. I don't seem to have a 4th spot??
I would be happy rigging it to low and high or medium or high.. but I definitely
need high for the A/C.
Any ideas???
Old 09-02-2021, 11:33 AM   #14
'72 C10 Super
Ok simple questions:
1. Does the fan switch have Off, Low, Medium and High?
2. Is there such a fan switch that only has Off, Low, High?
